Gravure filter effect
Jul 11, 2012 10:26 PM
hello forum.
im trying to achieve an old style drawing in photoshop if there is one using some filters maybe
thank you
    Jul 11, 2012 10:59 PM   in reply to inquestflash
    It would be a lot easier if you have a drawing that is already drawn with black outlines.
    You can recreate similar style with the filters Artistic>Crosshatch, Poster edges with some Texture filters. Test with the settings in each filter combinations and you will get interesting results.
    This page may help you out:
    http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-7986a.html
    Jul 11, 2012 11:10 PM   in reply to inquestflash
    I find Layers with monochrome Patterns set to Blend Mode Hard Mix can be quite useful.
    The lines can be attempted to be done with Find Edges on photographs, but if you start with an illustration consisting of lines that would be easier, as Sharon indicated.
    Jul 11, 2012 11:43 PM   in reply to inquestflash
    By randomizing (edit: blurred) Patterns one can get some effects …
    For illustrations one can use those pattern Layers and paint underneath them (different patterns or different directions naturally necessitate new Layers), the proper lines are best put one a separate higher Layer.
  • Trevor.Dennis
    May 24, 2010
    Jul 11, 2012 11:51 PM   in reply to c.pfaffenbichler
    I quite like the Topaz Simplify plugin for that sort of effect.  Uou can also reinforce, or clean up afterwards using black or white paint brush with the brush blend mode set to Overlay.
    Jul 12, 2012 12:19 AM   in reply to inquestflash
    No, I meant custom patterns.
    Just create a black and white Pattern, blur it somewhat (this may take some experimentation), set a Layer with that Pattern to Hard Mix and add a Hue/Saturation Layer set to 0 Saturation above – this would naturally be unnecessary if you work in grayscale right away.
    Jul 12, 2012 12:54 AM   in reply to inquestflash
    Like I said if the direction of the strokes of the patterns should conform to some shapes or planes it may be necessary to use several Layers and mask them to the appropriate areas.
