OK! I have a checkbox group populated in this way, I will chose from maybe 100 drills for golf players and put the drill_ID it together in a lookup table with players_id.
Maybe up to 20 drills per player.
Now can I organice the checkbox group in columns or rows so I dont get a 100 long list straight down?
If you're using PHP or ASP, Tom Muck has a free horizontal looper extension that you can obtain from here: http://www.tom-muck.com/extensions/help/horizontallooper/.
I bougt the horizontal vertical looper PHP from Tom Muck and got i to work here
Now I can't figure out how to insert a playerID (hidden field id) and a drillID (the loop) in a lookup table "exercise_spelare_ref" where I have 3 columns:
id drillID kommentar
21 32 NULL
21 34 NULL
21 47 NULL
35 31 NULL
35 33 NULL
I think I want it this way instead of comma separated, not sure why though ![]()
id and drillID are composite index kommentar is for later use (problems :-) a possibility to comment on every drill on a player level (id)
I understand that I should make a foreeach loop and end the checkbox name with [] to make an array maybe even the hidden field id, not sure.
With the standard Dreamweaver insert record I can only insert the last choosen checkbox along with the id.
Code here:
<?php
if(!isset($tfm_rows) || intval($tfm_rows) == 0){$tfm_rows = -1;}
if(!isset($tfm_columns) || intval($tfm_columns) == 0){$tfm_columns = 4;}
if(!isset($tfm_vertical)){$tfm_vertical = "true";}
<?php require_once('../dirName/fileName.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$insertSQL = sprintf("INSERT INTO exercise_spelare_ref (id, drillID) VALUES (%s, %s)",
GetSQLValueString($_POST['spelareID'], "text"),
GetSQLValueString($_POST['drillSelect'], "text"));
mysql_select_db($database_connect, $connect);
$Result1 = mysql_query($insertSQL, $connect) or die(mysql_error());
// Horizontal looper block 1 -- set up array, row and column values
$HLoop_Recordset1 = array();
$HLoop_Recordset1_rows = $tfm_rows;
$HLoop_Recordset1_columns = $tfm_columns;
$HLoop_Recordset1_vertical = $tfm_vertical;
if($HLoop_Recordset1_vertical == "true") {
$HLoop_Recordset1_loopTo = $HLoop_Recordset1_rows;
}else{
$HLoop_Recordset1_loopTo = $HLoop_Recordset1_columns;
$HLoop_Recordset1_i = 0;
$HLoop_Recordset1_ii = 0;
$HLoop_Recordset1_actualrows = 1;
$query_Recordset1 = "SELECT * FROM exercise";
$Recordset1 = mysql_query($query_Recordset1, $connect) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
$colname_rsSpelare = "-1";
if (isset($_GET['id'])) {
$colname_rsSpelare = $_GET['id'];
$query_rsSpelare = sprintf("SELECT id, user_login, first_name, last_name FROM analys_kund WHERE id = %s", GetSQLValueString($colname_rsSpelare, "int"));
$rsSpelare = mysql_query($query_rsSpelare, $connect) or die(mysql_error());
$row_rsSpelare = mysql_fetch_assoc($rsSpelare);
$totalRows_rsSpelare = mysql_num_rows($rsSpelare);
$query_rsRef = "SELECT * FROM exercise_spelare_ref";
$rsRef = mysql_query($query_rsRef, $connect) or die(mysql_error());
$row_rsRef = mysql_fetch_assoc($rsRef);
$totalRows_rsRef = mysql_num_rows($rsRef);
$query_Recordset1 = "SELECT drillID, categori, rubrik FROM exercise";
if ($HLoop_Recordset1_rows < 1){
$HLoop_Recordset1_rows = ceil($totalRows_Recordset1 / $HLoop_Recordset1_columns);
if($HLoop_Recordset1_loopTo < 1) {
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Välj Övningar</title>
</head>
<body>
<strong>Spelare: <?php echo $row_rsSpelare['first_name']; ?> <?php echo $row_rsSpelare['last_name']; ?></strong><br />
<br />
<form id="form1" name="form1" method="POST" action="<?php echo $editFormAction; ?>">
<?php
// Horizontal Looper start code for Recordset1
do {
ob_start();
<input type="checkbox" name="drillSelect" value="<?php echo $row_Recordset1['drillID']; ?>" id="drillSelect" />
<?php echo $row_Recordset1['rubrik']; ?>
</label>
<?php
// HLooper manage the arrays for Recordset1
$HLoop_Recordset1_temp = ob_get_contents(); //dump buffer to variable
ob_end_clean(); //clear buffer
$HLoop_Recordset1[$HLoop_Recordset1_i][$HLoop_Recordset1_ii] = $HLoop_Recordset1_temp;
$HLoop_Recordset1_ii++;
if($HLoop_Recordset1_ii >= $HLoop_Recordset1_loopTo){
$HLoop_Recordset1_i++;
$HLoop_Recordset1_actualrows++;
} while ($row_Recordset1 = mysql_fetch_assoc($Recordset1));
if($HLoop_Recordset1_actualrows < $HLoop_Recordset1_rows && $HLoop_Recordset1_vertical == "false") $HLoop_Recordset1_rows = $HLoop_Recordset1_actualrows;
if($HLoop_Recordset1_actualrows < $HLoop_Recordset1_columns && $HLoop_Recordset1_vertical == "true") $HLoop_Recordset1_columns = $HLoop_Recordset1_actualrows;
<table class="hloop">
<?php for($i = 0; $i < $HLoop_Recordset1_rows; $i++) { ?>
<tr>
<?php for($ii = 0; $ii < $HLoop_Recordset1_columns; $ii++) { ?>
<td><?php
echo(isset($HLoop_Recordset1[$ii][$i]) ? $HLoop_Recordset1[$ii][$i] : " ");
}else{
echo(isset($HLoop_Recordset1[$i][$ii]) ? $HLoop_Recordset1[$i][$ii] : " ");
} ?></td>
<?php } ?>
</tr>
<?php } // End Horizontal/Vertical Looper code for Recordset1 ?>
</table>
<input name="spelareID" type="hidden" value="<?php echo $row_rsSpelare['id']; ?>" />
<input type="hidden" name="MM_insert" value="form1" />
<input type="submit" name="submit" id="submit" value="Välj övningar" />
</form>
<p>
</p>
</body>
</html>
<?php
mysql_free_result($Recordset1);
mysql_free_result($rsSpelare);
mysql_free_result($rsRef);
Thank's in advance
Willy
I have been contacting Tom Muck but unfortunately he hasn't respond.
This seems to work though:
<?php
$id = $_POST['spelarID'];
$drills = $_POST['drillSelect'];
$inserts = array();
foreach ($drills as $drills)
$inserts[] = "('$id','$drills','')";
$query = "INSERT INTO exercise_spelare_ref VALUES ". implode(", ", $inserts);
//echo "query = $query"; // for debugging purposes, remove this once it is working
mysql_query($query) or die(mysql_error());
id and drillID are now inserted in Myssql table "exercise_spelare_ref" with new rows for every checked value.
Then ofcourse a new question appears. When I want to make a update page where the inserted records shows as Checked I cant manage to pull that out of the table.
In a non dynamic checkbox I would do something like:
<input <?php if (!(strcmp($row_rsRef['drillID'],1))) {echo "checked=\"checked\"";} ?> type="checkbox" name="CheckboxGroup1" value="1" id="CheckboxGroup1_0" />
chkbox1</label>
I abandoned the Tom Muck looper and made a sandard Dreamweaver "Repeat Region" and "Recordset Pagin".
With the new code below I can (for test reason) echo correct id and drillID corresponding to every checkbox.
<?php do { ?>
<tr>
<td width="96">
<?php
$id = $row_rsRef['id'];
$drills = $row_Recordset1['drillID'];
//echo $id;
//echo $drills;
$arr = array($id,$drills);
$selected = implode(", ", $arr);
echo $selected;
</td>
<td width="784">
<input <?php if ($row_rsRef['drillID']==$drills) {echo "checked=\"checked\"";} ?> type="checkbox" name="drillSelect[]" value="<?php echo $row_Recordset1['drillID']; ?>" id="drillSelect" />
</label>
</td>
</tr>
<?php } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1)); ?>
You can see the output here.
Then I think I should be able to show the checkbox as "checked" in some way (obviously not the ways I have tried) by using one or another of the variables $id, $drills or $selected if the row exists in the lookup table "exercise_spelare_ref" where the values are inserted, when I want to do an update.
1559 1 NULL
1559 4 NULL
1559 9 NULL
1560 1 NULL
1560 9 NULL
