Hi all,
I'm working on a form which has a title with a very large font size. In the design view I have entered that it should be 120 large. Whenever I switch to PDF view, the font gets resized to a small value like 12. I f I select a value of 72 then in the deisgn view I can see the configured value.
Is there a limitation to the maximum size of the font I can use ? ( Helvetica Neue LT STD )
Total Likes
I'm not sure what's the problem at your end.
I had not problems using that font in a text and I could enter a size between 1 - 999.
What happens when you open the form in Acrobat or Reader instead of the preview?
Total Likes
Tx for reply.
Same thing happens in the end result PDF in Reader. The font size is adjusted in the form view, there I can indeed adjust to 999 but when I do that ( or in my case 120 ), the preview and now also the actual PDF show it as smal font.
Total Likes
Can you share your form?
Total Likes
