Suggestions for disk setup
Jul 12, 2012 3:24 AM
Dear All!
Id like to make a claen install.Before that id like to ask your advice for some disk setup, or modification.Is there some cheap solution to improve the system, ( maybe to buy or replace hdd-s or ssd-s).
My config was this : C: OCZ revodrive X2 160GB ( OS)
                                D: 240Gb Corsair Force 3 (Media cache, previews, pagefile)
                                E : 2*1TB Samsung 7200 RAID 0 ( Project files )
                                F : 2,5 TB WD Green (Export )
My revodrive too slow now (under 200Mb/s , tested with HD Tune).The retailer recommended a clean install before I send back the item.So maybe they change this product, maybe I can choose another type of SSD.In this case what is a good choise?
Thanks in advance.
    Jul 12, 2012 6:02 AM   in reply to Dvico
    Personally I would replace your D: drive with a small 7200 rpm drive as you do not want to be using a SSD for heavy writing tasks.  Then I would get the green drive out of the editing path and use it for backup/archiving only.  Since you have a RAID 0 array for your project files, exporting to a single green drive will be much slower that exporting to your RAID array.  Now if you can configure another RAID 0 that would be ideal for the exports
    Jul 12, 2012 6:49 AM   in reply to Dvico
    Here's the deal:
    While SSDs are fast, they also have limited rewrite life. And when an SSD is used as a media cache dribe, it can use up its entire rewrite life cycle in only a few weeks to a few months of use! This is because media cache requires repeated rewrites to a disk.
