I just acquired this software you see, and I've been working on a multi-track project all day. Every file other than the instrumental I'm using, are vocals, and they all have effects on them. Here is my problem, whenever I export my song, it messes up my effects, and downgrades the quality of my vocals! Even in wav format! I am beyond frustrated at this point, and can't seem to find the answer to my problem anywhere!
Please help!
I have no idea about that. I'm pretty sure my computer is using a basic type of sound card, if any. Though I think it's a realtek hd card. It's not tailored for making music or anything. I also tried listening to the track in quicktime player, and it sounded good in there as well. You seem pretty informed on the subject, do you have any idea what could be causing this? Because I'm listening to all of this on my headphones, not changing devices or anything.
From what you are saying we have established that you have one onboard Realtek soundcard and that your mix sounds good/as expected through both Audition and Quicktime but not Winamp
Logic tells me that the problem is with Winamp - probably some sort of fx or setting that you are unaware of
What format are you saving your final file? If it's a WAV, you may need to be certain to convert it to 16-bit. By default, Audition keeps files as 32-bit which preserves quality through edits and saves, but which is not necessarily compatible with some players. From the editor, click Edit > Convert Sample Type and change the Bit Depth to 16. Save as a new file and see if you have better luck in Winamp.
