NawaraGFX
How can I can write Arabic in Adobe Illustrator CS6 ?
Jun 25, 2012 5:42 AM
How can I can write Arabic in Adobe Illustrator CS ?
I use Adobe® Creative Suite® 6 Design & Web Premi
And I write Arabic in Adobe photshop CS6 but I can't write in  Illustrator and  indesign
PLZ help me .
    Jun 25, 2012 6:19 AM   in reply to NawaraGFX
    You need a font like Geeza Pro loaded, set up your keyboard preference and choose arabic for an input mode. You will want the middle eastern ME version of AI instlaled as typing backwards will not give you accurate results.
    http://helpx.adobe.com/mena/using/arabic-hebrew.html
    Jun 25, 2012 3:06 PM   in reply to NawaraGFX
    Write it in ID and paste it into Illustrator that should work although there might be some reflow problems and oncer pasted into Illustrator you might be then able to input the text as you expect.
  • Ivan David
    Jun 9, 2010
    Jun 28, 2012 11:05 PM   in reply to NawaraGFX
    In Photoshop, Middle-east/North-african type (MENA) is enabled in all editions. In Illustrator and InDesign, you need the MENA-enabled editions of the software. Please use these links to download the trial and explore Arabic language support in Illustrator:
    Cheers,
    David
    Oct 23, 2012 6:55 AM   in reply to NawaraGFX
    A solution to enable Arabic in InDesign or in Illustrator is to install ScribeDoor, a plugin from WinSoft Intl: http://store.winsoft-international.com/products/product/winsoft/scribe door.html
    Hope this helps
    Pascal
    Oct 23, 2012 1:11 PM   in reply to NawaraGFX
    you can get an AI file with arabic formated text already in it, you can then use that existing text and replace it by copying new text into it or typing.
    you can also create a paragraph or character style from existing document with arabic in it and apply it to other arabic. you can of course save the character styles into your default document.
    you can search for an AI document with different arabic format options and make styles out of those because you won't be able to change type option like Kashidas, arabic or naskh justification
