problem with creative cloud and lr4.1
Jun 30, 2012 5:40 AM
Tags: #creative_cloud #registration
Hi...
I have been a member of the Creative Cloud since day one (sometime in May). About a month ago I downloaded the trial version of LR 4.1. Four or 5 days ago, LR became part of Creative Cloud. At that time, I de-installed the trial version and installed LR4.1 via the Creative Cloud, no problem. Today as I opened LR, I received a message that says I have one day left on my trial! I have no idea what to do...I cannot find a way to activate the program via the Cloud.
Please help...only one day left in the trial! Thanks!
  • Victoria Bampton
    Apr 1, 2008
    Jun 30, 2012 11:29 AM   in reply to BTJ
    Your best bet is to try the chat support at http://adobe.ly/yxj0t6
  • Victoria Bampton
    Apr 1, 2008
    Jul 1, 2012 12:45 PM   in reply to BTJ
    Sorry BTJ!  Is it still alive today?
  • Victoria Bampton
    Apr 1, 2008
    Jul 1, 2012 1:17 PM   in reply to BTJ
    Oh that's good news!  Let me know what the solution is, won't you.
  • Victoria Bampton
    Apr 1, 2008
    Jul 2, 2012 8:18 AM   in reply to BTJ
    Are you Mac or PC?  Did you use previous LR versions?  I'm wondering if it's picking up older serial numbers and thinking you want to upgrade.
    (As a very temporary workaround, turning back your computers clock *may* help keep it running as a trial until we figure out what's going on.)
  • Victoria Bampton
    Apr 1, 2008
    Jul 6, 2012 1:43 AM   in reply to BTJ
    I'm really pleased they're following it up BTJ.  I tried to switch my (licensed) version to a Creative Cloud registration, and couldn't get that to work either, so they're probably right.  At least it's still working.
    Jul 6, 2012 1:43 PM   in reply to BTJ
    The trial software issue is becoming a recurring problem with cloud apps. The Creative Cloud appears to be having some intermittent difficulties keeping track of trial vs subscription. Other users have reported that clicking through to the software has no impact on the ability to use it. Sometimes it goes away and returns. sometimes it doesn't. I even had a conversation with a user who was being told they had -1 days left on the trial.
    This is on Adobe's radar and should be fixed shortly (I hope). So, don't worry. You are alone. If your copy of LR does stop functioning let tech support know immediately. This is definitely a glitch.
    Jul 11, 2012 11:32 AM   in reply to BTJ
    We just released an update to Adobe Application Manager that addresses the issue with Creative Cloud products reverting to trial, you might install the updated version of AAM and see if it resolves the issue for you.
    CS6 applications in Creative Cloud unexpectedly revert to trial mode
    http://helpx.adobe.com/creative-suite/kb/trial--1-launch.html
    -Dave
    Jul 11, 2012 6:00 PM   in reply to BTJ
    Thanks for testing that. I was hoping it would be the solution for you. A couple questions.
    - Do you still get the trial screen if you launch LR 4.1 by going to its shortcut in the start menu and right-clicking on it and choosing "Run as Administrator"?
    - Do you use any Anti-virus or Firewall software on your computer? if so which one?
    - It would be a good idea to collect some log files from the temp directory on your system, oobelig.log and PDApp.log. Please press/hold the Window key on your keyboard (typically between Ctrl & Alt on left side of the spacebar) and press R to bring up the Run prompt, type %temp% in the field and click OK. These two files should be in that directory and have been created when you reinstalled the products. If you could move them to the desktop in order to attach them to the case for assisting our technical support department.
    -Dave
    Jul 12, 2012 10:10 AM   in reply to BTJ
    Warren,
    Thanks for the additional information and collecting the log files. Licensing in Lightroom works differently than other CS6 programs and its normal that "Lightroom Registration" would appear instead of "Activate" or "Deactivate". The registration option will make it so Lightroom is included is the listed of programs you have registered with your Adobe ID. You should only need to complete the registration process once. Support should be able to register the product to your Adobe ID as well. Does the trial screen still appear if you don't click on the registration option?
    Thanks for testing the Run as Administator too.
    -Dave
    Jul 12, 2012 12:40 PM   in reply to BTJ
    Hey Warren,
    Its normal that Lightroom 4 appears registered separately. This is because the licensing for this product works a little different than the others. The serial number starting with 1160 is typical as well. I checked the serial number you have associated with your account and it is valid and appears normal. I think the agent you spoke with was just mistaken.
    The way it should work is after installing Lightroom through the Adobe Application Manager you should be done. When you launch Lightroom it should just open and you should be all set.
    If I go to the Help > Registration in LR on my Windows 7 x64 system I get the following window. If I fill it in and click the Finish button it goes away and I'm just back in the program, no prompts for a serial number or screen saying 0 days remaining, etc. Could you post a screen shot of where it goes different for you?
    Jul 16, 2012 5:05 PM   in reply to BTJ
    Thanks Warren,
    I'm not able to see the screen shot, is it possible to try posting it again? It doesn't sound like the behavior you are experiencing is not normal but if it only happens when going to Help > Registration then its probably not going to affect much. Does everything else with Lightroom seem to be working okay?
    Best,
    Dave
    Aug 6, 2012 6:53 PM   in reply to David__B
    Likely Warren is responding to the email about this post being updated, attaching the image to the email.
    Warren, in order to post a screen shot, you have to come to this website and use the Camera button at the top of the reply window.
    Looking at David's Registration Window above, on the left hand column you can see where it says "License". Do you have a green checkmark next to it like he does? If not, then your serial number isn't accepted. If you do, then your product is fully licensed.
    If you are only seeing a message about the trial when coming into this window, then stop going to the Lightroom Registration window. There isn't anything for you to do from here, your product is already registered as part of your subscription.
