Hi, I have some files in Illustrator, Photoshop, and InDesign that I wish to be backwards compatible with CS5.
I'm concerned more about my Illustrator files at the moment.
I'm not sure how to save as a CS5 file or if there is an automatic way to make it compatible overall.
I am on a MBP.
Any more questions, please post.
Thanks.
-As far as I know for Photoshop, it's under Preferences, General, File Handling, Maximise PSD Compatibility: Always.
Is this correct?
I found this on another forum, but is there a more permanent solution to this?
So I don't have to Save As everytime?
Aka I want to save everytime and not have to worry about compatibility issues.
To clarify your answer for Illustrator. The option is not in the "Save As" dialog box.
The correct answer is
Open you CS6 Illustrator file.
File>Save As
The Save As dialog box opens
Type your file name (DIFFERENT THAN ORIGINAL PLEASE!) and the Save as Type is still going to be Adobe Illustrator (*.AI) **This is where the above instructions threw me, as the Save as type drop down does not list anything about versions to save fo)
Click Save
Once you click Save, the Illustrator Options dialog box will come up. The first option is titled Version and has a drop down menu. Select the version of illustrator you want to save your file as here, then click ok.
Your done.
I strongly suggest you give this file a different name than your original CS6 Illustrator version as you may lose some parts of your design in the conversion.
Hope this helps. Enjoy!
Hi bro, your suggestion is not work. I trust you and save as you said but all the certificate we printed was rejected.
The quantities we printed are not a small quantity. Wooowwww.... I can't sleep for threee day and night.
So pls any body there could help me to save CS6 file to CS5 without warning dialog box.
Thanks.....
For Illustrator: " Check for save in illustrator format "
For Indesign :
http://helpx.adobe.com/indesign/kb/save-indesign-files-previous-versio ns.html
For Photoshop :
http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-7758a.html
