attach XML playlist
Jul 12, 2012 6:30 AM
I'm creating xml player. xml process and playing single video is fine. i stuck at multiple videos playing. give me any solution please..?
i have 3 buttons, if i click button_1 play first video, or if i click button_3 play 3rd video.
how to attach videoURL = playlist files.
var myXML:XML;
var myLoader:URLLoader = new URLLoader();
myLoader.load(new URLRequest("video_list.xml"));
myLoader.addEventListener(Event.COMPLETE, processXML);
 function processXML(e:Event):void
          myXML = new XML(e.target.data);
          trace(myXML.Video[0]);
button_1.addEventListener(MouseEvent.CLICK, btn1Click);
button_2.addEventListener(MouseEvent.CLICK, btn2Click);
function btn1Click(e:MouseEvent):void
          ns.play(myXML.Video[0]);
function btn2Click(e:MouseEvent):void
          ns.play(myXML.Video[1]);
var videoURL:String;
//var videoURL:String = "http://www.helpexamples.com/flash/video/cuepoints.flv";
var nConnection:NetConnection;
var ns:NetStream;
var video:Video = new Video();
nConnection = new NetConnection();
nConnection.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
nConnection.connect(null);
function netStatusHandler(event:NetStatusEvent):void
          switch (event.info.code)
                    case "NetConnection.Connect.Success" :
                              connectStream();
                              break;
                    case "NetStream.Play.Stop" :
                              break;
                    default :
function connectStream():void
          ns = new NetStream(nConnection);
          ns.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
          vidDisplay.attachNetStream(ns);
          ns.play(videoURL);
XML
<?xml version="1.0" encoding="utf-8"?>
<Playlist>
<Video Title="Chapter 1">media/video_1.flv</Video>
<Video Title="Chapter 2">media/video_2.flv</Video>
</Playlist>
  • kglad
    Jul 21, 2002
    Jul 12, 2012 7:16 AM   in reply to Venkom
    you only have code for two buttons and you've got screwy code in your netStatusHandler.
    try:
    var myXML:XML;
    var nConnection:NetConnection = new NetConnection();
    var ns:NetStream = new NetStream(nConnection);
    video.attachNetStream(ns);
    addChild(video);
    function netStatusHandler(event:NetStatusEvent):void {
    // you have no useful code here
  • kglad
    Jul 21, 2002
    Jul 12, 2012 9:52 AM   in reply to Venkom
    use:
    var myXML:XML;
    videoURL=myXML.Video[0];
    videoURL=myXML.Video[1];
    var ns:NetStream
    addChild(video);
    play_btn.addEventListener(MouseEvent.CLICK, playClicked);
    pause_btn.addEventListener(MouseEvent.CLICK, pauseClicked);
    play_btn.visible = false;
    var videoPaused:Boolean = false;
    function playClicked(e:MouseEvent):void{
              if(!videoPaused)
                        ns.play(videoURL);
              else
                        ns.resume();
    function pauseClicked(e:MouseEvent):void
              ns.pause();
      play_btn.visible = true;
              videoPaused = true;
  • kglad
    Jul 21, 2002
    Jul 12, 2012 11:30 AM   in reply to Venkom
    everything should work as long as you wait for xml loading to complete before clicking your buttons.  you can disable those buttons when you app starts and enable them in processXML.
    var myXML:XML;
    button_1.enabled=true;
    button_2.enabled=true;
    button_1.enabled=false;
    button_2.enabled=false;
    var ns:NetStream
    addChild(video);
              if(!videoPaused)
                        ns.play(videoURL);
              else
                        ns.resume();
              ns.pause();
              videoPaused = true;
  • kglad
    Jul 21, 2002
    Jul 13, 2012 6:48 AM   in reply to Venkom
    you're welcome.
