y_andrei
A slight change of position
Jul 12, 2012 9:24 AM
Hi!
I've noticed that sometimes a button chage its position when clicked (even if I made it NOT TO CHANGE the position), but in an almost unnoticeable way. It's, actually, a slight change of position. Usually the button goes to the right or left, and what I can tell you is this:
The scene starts and the buttons are actually graphics so there's no option of clicking (and, therefore, interrupt the intro) while the scene is in its intro movement. When it gets to the frame STOP, the graphics change into buttons as such; in other words, there's no difference in visual terms between the graphics and the buttons, the difference in based only in the code (either it is a graphic or a button). OK
It happens that I've noticed this slight change of position when it gets to the frame STOP. It's important to remind that I did a BREAK APART in the scene intro, in other words, I copied the button which is in the frame STOP, pasted in the intro and applied a BREAK APART comand so it becomes a common object.
As I said: it's almost unnoticeable, this change of position; but Im wondering why it happens. Does anyone know?
Thanx!
  • kglad
    Jul 21, 2002
    Jul 12, 2012 9:55 AM   in reply to y_andrei
    you have mis-aligned the graphics in your button's frames.
