trialboj
How can i create transparent mask?
Jul 12, 2012 10:13 AM
Tags: #mask #transparent #after #effects #hide
i want to hide some text but i want to keep the main background at the back of the text, what can i tick, and where?...
i hope its understandable.
    Jul 12, 2012 11:08 AM   in reply to trialboj
    In a composition select your text layer then select Pen Tool and draw a mask.
    See more help on creating masks and shapes.
    Jul 12, 2012 11:46 AM   in reply to trialboj
    Not sure I understand what you actually want, but now you're trying to create a mask on a shape layer, which is your black rectangle, instead of a text layer...
    So as to hide a part of a text layer you don't need a shape layer over the text layer at all...
    If you want to use your shape layer as a track matte, click 'Toggle Switches/Modes' button until 'TrkMat' column appears, then click according drop down list and choose your shape layer as 'Alpha Inverted Matte' for the text layer - that will hide both the shape layer and a part of a text beneath.
    Or explain what you're trying to achieve more clearly...
    Jul 12, 2012 12:35 PM   in reply to trialboj
    Then the easiest way is using your shape layer as 'Alpha Inverted Matte'
    Jul 12, 2012 1:12 PM   in reply to trialboj
    Check the Opacity of your Shape Layer 2 - you seems set it to 0%...
