java script/jquery help for a a webform in the booking module
Jun 4, 2012 5:57 PM
Tags: #jquery #javascript #event #bookings #booking
I need to create a webform in the booking module where the first picket would cost X amount and all following tickets will be priced at Y. I already employ a "Booking multiple seats under one name" method but now I need help with the java script/jquery to be able to price the additional items  differently.
Thank you,
Lana
    Jun 5, 2012 11:44 AM   in reply to Lana_Studio
    Do you have a URL of an example form you've already started on so we could possibly work from that?
    Jul 9, 2012 2:18 PM   in reply to Lana_Studio
    I am using the same "Booking multiple seats under one name" method in a project needs a pricing structure as you describe. I edited the bookings.js as follows:
    // Bookings multiple seats script
    //By: Mario Gudelj
    //modified by Janice McConnell to create 2 ticket prices and calculate total.
    (function($){
    bookings = function() {
    var bookingAmount = 50; //Booking amount in dollars
    var guestAmount = 100; //Booking abount variable for each guest - added code
        $('#seats').change(function() {
            $('.webform').fadeIn("slow");
            var noOfSeats = $("#seats option:selected").val();//take the selected option from the dropdown
            var noOfGuests = parseInt(noOfSeats) - 1; //The number to pay guestAmount for a ticket - added code
                $('.hide').fadeOut("slow");
                $('#BookingAllocation').val(noOfSeats);             //set the number of seats
                //totalAmount = bookingAmount * noOfSeats;
                var    totalAmount = memberAmount + guestAmount * noOfGuests; //New calculation based on number of tickets at each price
                $('#Amount').val(totalAmount);
                for(var index = noOfSeats; index > 0; index--){
                    $('.person'+index).fadeIn("slow");
            $('.total').html("<span>TOTAL:"+totalAmount+"</span>");
    })(jQuery);
    I hope this helps.
    Now if I can figure out how to create a usable report on bookings . . .
    Jul 11, 2012 6:37 PM   in reply to Lana_Studio
    I may be able to help you with this, but it will be a few days before I can look
    at it. You may have it figured out by then.
    Janice
    Janice McConnell, CEO
    MJ WebWizards, Inc.
    5057 Strickland Rd
    Gainesville, GA 30507
    770-967-6742
    Jul 12, 2012 12:42 PM   in reply to Lana_Studio
    Try this:
    //By: Mario Gudelj
     // ammended by Janice McConnell to include use of discount codes. Note that an
    input field for the discount code should be added to the html page.
    (function($){
    var discountAmount = 0;
      var noOfSeats = $("#seats option:selected").val();  //take the selected option
    from the dropdown
       totalAmount = bookingAmount * noOfSeats - discountAmount;
      $('.total').html("TOTAL:"totalAmount"</span>");
     //When user enters discount code and moves focus, this function fires.
     $('#disCode').blur(function() {
      var discountCode = $(this).val(); //get the discount code
       //Compare discount code to the case values and set discount amount. Note all
    codes and values should be added to switch statement
      switch (discountCode) {
        case 'DIS5':
        discountAmount = 5;
      break;
        case 'DIS10':
        discountAmount = 10;
       break;
        case '':
        discountAmount = 0;
        break;
        default:
        alert('Please enter the valid code');
      var newTotal = bookingAmount * noOfSeats - discountAmount; //Recalculate total
    based on number of seats and then subtract discount
      $('#Amount').val(newTotal); //set new Amount
    }})(jQuery);
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Jul 12, 2012 2:50 PM   in reply to Lana_Studio
    The line in the js file is:
    I notice your line desn't have the opening span tag. Do you have an element with
    class="total"?
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Jul 13, 2012 8:40 AM   in reply to Lana_Studio
    Best guess is "no". You don't really need another field in your form. Take this
    line out of the bookings.js:
    and don't add a field with that class.
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Jul 13, 2012 12:38 PM   in reply to Lana_Studio
    Sorry about that. Add the 2 lines around the existing middle line:
    $('#Amount').removeAttr('readonly');
            $('#Amount').attr('readonly','readonly');
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Jul 13, 2012 3:13 PM   in reply to Lana_Studio
    Just popped in and noticed on your site that when you choose a number of participants in the booking, the form loses the decimal places no it doesn't resemble a dollar amount (at least USD).  In order to maintain the decimal, just change line 15 of the bookings35.js file to this:
    totalAmount = (bookingAmount * noOfSeats).toFixed(2);
    You can see a demo I worked up at http://jsfiddle.net/BzqN5/
    In my example, I changed the bookingAmount variable in the javascript to 12.75 to ensure that the decimals were being handled correctly.  If you change it back to 35 and save the fiddle again, you can verify it works for round numbers too-- keeping the .00 at the end.
    Aug 25, 2012 5:19 AM   in reply to Lana_Studio
    Guys, I have followed this thread with interest and am implementing a similiar booking module. My question : is it possible to have a variable amount for multple events that works with the Multiple Seat Bookings under one name concept. I have the booking working with one amount but now have muplitple events with different pricing. Ie: 1st Event  $96-00 2nd event $150.00.
    When using this script can anyone tell me what the variable price should indicate or where in the form this should be indicated. I am so close but can't quite crack it and would really appreciate some help.
    (function($){
    var bookingAmount = 0.00; //Booking amount in dollars
            var noOfSeats = $("#seats option:selected").val();  //take the selected option from the dropdown
    })(jQuery);
    Thanks in anticipation.
    Rossco
    Aug 25, 2012 6:10 AM   in reply to Harplane
    I set the cost for each event in the content of the event in the event modules
    section. Then I added jquery code to get  that amount for each event and use it
    in the original code rather than hard-coding the amount in the original code.
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Aug 25, 2012 7:35 AM   in reply to jymcconn
    Janice I have applied the above code to my site wide template to act with all bookings with separate booking forms. Is there a way to enable one "booking multiple seats script " i(in template ) ie ; amount change with each No of Seatys allocation.and then have the booking form code display the separate price for each event.  I have it working on one event but price is set in the template script. This has got me beaten.  If not where are you seating the script wthin the individual event pricing.
    Thanks for your help it is most appreciated.
    Rossco
    Aug 25, 2012 8:26 AM   in reply to Harplane
    We have an Events template that has a call to the script file. When you go to
    the dashboard, select Modules>Events> and open a specific event, you will see
    the Event Content field. This is where we have the details for each event and a
    content-holder with the registration form. In the details section, we have an
    element for the cost of the event with an id applied. When the event is opened
    on the Events page, the code gets the text of the element,  changes it to a
    decimal number and sets the cost per ticket variable. Something like:
    var bookingAmount = parseFloat($('#ticketCost').text(),10);
    where "ticketCost" is the id of the element in the event description which
    contains the price of the ticket. Make sure that the amount doesn't contain the
    dollar sign. In one case,I  made a span for the price with the dollar sign
    outside the span. In another case, I tested for its presence and stripped it -
    probably the better, cleaner way - I should mention that I am not an expert.
    You ask " If not where are you seating the script wthin the individual event
    pricing." If I understand your question - I'm not. The individual event pricing
    is seated in the event content. The script is seated in the Events template.
    This may not fit in with your design at all, but perhaps it will give you some
    new ideas.
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
    Aug 26, 2012 6:15 AM   in reply to jymcconn
    Thanks so much Janice. This hasn't quite worked for our situation but have established new templates for each event which is great for now. Have everything working now in content holders which is perfect. Having a problem with trying to get the multiple seat names top display in the workflow. This seems to be a common problem with the BC Platform,, where only the email subscribers name appears in the booking. Do you know of any way that we can make all names subscribed appear to the booking.  Thanks again your assistance was invaluable. Cheers from Aus.
    Rossco
    Aug 26, 2012 9:10 AM   in reply to Harplane
    My client was satisfied to have the names appear in a custom report. So we
    "extended the CRM database" with a list of text fields for guests for  the
    registration form. Now we can do a custom report of "Customers and Bookings" and
    add the CRM extension to the report. The report then shows the "guest" names
    with each registrant's name.
    I considered trying submitting multiple forms, but since this was working and
    sufficient for the client, I didn't follow up on it.
    Hope this helps.
    Janice
    MJ WebWizards, Inc.
    5057 Strickland Rd
    770-967-6742
