Text Indent
Jul 11, 2012 4:57 PM
Tags: #adobe #cs5.5 #code #dw
How do I indent both lines of text on this page?
http://lash-it.com/nav_matrix_faq_sample.html
Text-indent -10px on the #nav rule only indents the first line. I want to shift both lines of text slightly to the left so they look centered in the ovals.
    Jul 12, 2012 12:22 AM   in reply to kcfi
    Use  a <span></span> tag inside the anchor tag (see code and css below)
    <!doctype html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Lash-it Menu Example</title>
    <style>
    #nav {
        padding: 0;
        list-style-type: none;
        font-family: Verdana, Geneva, sans-serif;
        font-size: 14px;
        width: 880px;
    #nav li {
        float: left;
        margin: 0 0 0 20px;
    #nav li a {
        display: block;
        text-transform: uppercase;
        width: 196px;
        height: 62px;
        text-decoration: none;
        background-image: url(http://www.lash-it.com/images/nav_matrix_faq.png);
        background-repeat: no-repeat;
        color: #FFF;
        padding-top: 15px;
    #nav li a span {
        display: block;
    width: 187px;
    text-align: center;
    #nav li a:hover, #nav li a#current:hover {
        background-position: 0 -78px;
        color: #FFF;
    </style>
    </head>
    <body>
    <ul id="nav">
        <li><a href="buy/buy.html"><span>Frequently<br>Asked Questions</span></a></li>
        <li><a href="what/what.html"><span>Use<br>Tips</span></a></li>
      <li><a href="who/who.html"><span>Installation<br>Tips</span></a></li>
        <li><a href="dealer/dealer.html"><span>Detailed<br>Instructions</span></a></ li>
    </ul>
    </body>
    </html>
    Jul 12, 2012 2:36 AM   in reply to kcfi
    You're using text-align: center. So the text is centered. The problem lies with the background position of your ovals.
    I did a quick experiment, adding background-position: 10px 0; to your #nav li a rule. It needs some fine tuning, but I think that's where the best solution lies. Get the position of the image right rather than mess around with <span>s and such.
    Jul 12, 2012 8:36 AM   in reply to David_Powers
    There is  a drop shadow on the image so no way can you have text-align center on the anchor tag and have both the text and image centered using the anchor tag that's why I introduced a span tag.
    background-position 10px 0; doesnt move the image left of right either which is needed to compensate for the drop shadow.
    Jul 12, 2012 9:14 AM   in reply to osgood_
    You can if you design the background image to take the drop shadow into consideration. I just moved the background position of the image to demonstrate the effect of shifting the image.
    Jul 12, 2012 9:23 AM   in reply to David_Powers
    If the width of the 'a' tag is the same width as the oval (minus the drop shadow) then you can use text-align center. BUT the 'a' tag needs to be wider to show the drop shadow, then the text is off center horizontally. You can't move the background image left because that would cut off part of the image.
    Jul 12, 2012 9:37 AM   in reply to osgood_
    Take a look at the rough example I created for the OP yesterday: http://foundationphp.com/test/lashit.html. The background image (http://foundationphp.com/test/images/nav_matrix.png) has a slightly wider blue margin on the left to compensate for the drop shadow. The padding provides sufficient width for the whole of the background image to be displayed.
    Jul 12, 2012 10:22 AM   in reply to David_Powers
    In the interests of modern CSS and progressive enhancement, I would consider this a far better approach:
    http://www.projectseven.com/testing/fubar-109/
    No images were harmed - or hacked
    Al Sparber - PVII
    The Finest Dreamweaver Menus | Galleries | Widgets
    Since 1998
    Jul 12, 2012 10:23 AM   in reply to David_Powers
    Ok, I guess there is more than one way to skin a cat. Wasn't looking into it too deeply just what came into my mind at the time, which also works.
    Jul 12, 2012 10:28 AM   in reply to Al Sparber
    Al Sparber - PVII
    Since 1998
    OOOO!
    Thats a bit crazy. Neat.
    Jul 12, 2012 11:09 AM   in reply to Al Sparber
    I'm in 100% agreement with you Al. I made a similar suggestion in a related thread but the OP didn't go for it.
    Nancy O.
    Jul 12, 2012 2:53 PM   in reply to Al Sparber
    A great solution -- as long as you don't mind it not looking so great in IE 8.
    Not quite your usual colour scheme though, Al.
    Jul 12, 2012 2:56 PM   in reply to kcfi
    kcfi wrote:
    Maybe someday an oval shape can be created using CSS.
    It already can, at least in modern browsers (doesn't work in IE 8 or earlier):
    .oval {
        width: 200px;
        height: 100px;
        border-radius: 50%;
        background-color: #F00;
    Jul 12, 2012 4:50 PM   in reply to kcfi
    Jul 12, 2012 4:58 PM   in reply to kcfi
    If you're using this as a menu system, you would want to put links into unordered lists <ul> <li> tags.
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml">
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <title>Untitled Document</title>
    <style type="text/css">
    ul#oval {margin:0; padding:0; list-style:none;}
    #oval li a {
    margin:0 12px 0 12px; /**space between links**/
    width: 250px;
    height: 75px;
    border-radius: 50%;
    /**shadow**/
    -webkit-box-shadow: inset 2px 2px 10px #900;
    -moz-box-shadow: inset 2px 2px 10px #900;
    display:block;
    float:left;
    line-height: 75px;
    font-size: 16px;
    font-weight: bold;
    color: #000;
    text-align:center;
    text-decoration:none;
    #oval li a:hover,
    #oval li a:active,
    #oval li a:focus {background-color: #FFF;}
    </style>
    </head>
    <body>
    <ul id="oval">
    <li><a href="#">Some link</a></li>
    <li><a href="#">Another link</a></li>
    <li><a href="#">Some more links</a></li>
    <li><a href="#">A link with very long text...</a></li>
    </ul>
    </body>
    </html>
    Nancy O.
    Jul 12, 2012 5:27 PM   in reply to Nancy O.
    The earlier examples are unordered lists:
    The last thing you would want to do, though, is assign a height on text
    link. Different computers and different people have a nasty habit of
    rendering or setting font sizes that are not default on your computer or
    mine
    Al Sparber - PVII
    since 1998
    Jul 12, 2012 5:35 PM   in reply to David_Powers
    A great solution as long as you don't mind it not looking so great in IE8
    Progressive enhancement, which can also mean design to your client's computer
    If you hadn't left our beta team, you would know my palette has expanded
    Jul 12, 2012 7:46 PM   in reply to Al Sparber
    @Al,
    MIN-HEIGHT  would work but be an atrocity with increased text-size, yes??
    N
    Jul 12, 2012 8:01 PM   in reply to Nancy O.
    I'm pretty sure I just used line-height on my little example page. At
    least that way, if the user has a custom font set for computer or
    browser, the box will expand instead of the text breaking out of the
    box. I would never fix width on a menu as the original poster seemed to
    want to do. If there was a design mandated by a client I would likely
    have done the links as embedded images instead of text.
    The Web design community has slowly come to its senses (at least the
    smart ones) and understands that there is absolutely nothing wrong with
    using images - rather than image replacement, backgrounds, or worse -
    sprites.
    Al Sparber - PVII
    Jul 13, 2012 2:15 AM   in reply to Al Sparber
    'Twas nothing personal. Just phenomenally busy. Glad to know you've discovered new shades of grey.
    Jul 13, 2012 2:49 AM   in reply to kcfi
    kcfi wrote:
    One thing I have realized by using this forum is that everyone has a different way of doing things.
    That's very true. If you're interested in good techniques, you'll learn a lot from Al Sparber. Although the forum shows him as a member since only 2009, he's been an active participant for about 10 years longer. Al runs Project Seven, a very successful business creating excellent templates and extensions for Dreamweaver. We don't always agree, but Al's knowledge of CSS is second to none, and he offers a lot of free advice.
    Nancy O's a pretty smart cookie too.
