Why can't I upload a 2046x1536 folio, but I can view it on ipad2 via USB?
Jul 11, 2012 4:59 PM
Tags: #dps #folio #upload #ipad3 #2048x1536
No problems uploading 1024x768 smooth scroll PDF folios, they appear in my Content Viewer Library instantly on ipad2. But when I create a smooth scrolling PDF folio at the higher resolution, the only way i can preview it is by connecting to USB, (which displays it fine). The Content Viewer library updates but nothing happens. Folio Producer says my folio is "in the cloud" then why won't my ipad2 Content Viewer pull it down? I also note that in Folio Producer:Organizer, the content viewer version is listed as "unspecified". Is this the problem? how do I tell Folio Producer which version I have?
(In case you are wondering I'm using the higher 2046 res because I wasnt happy with the 1024 result - rasterisation DPS is doing to PDF overlays, very apparent when use Pinch & zoom)
thanks.
  • Bob Bringhurst
    May 29, 2007
    Jul 11, 2012 5:39 PM   in reply to mitchiedog
    2048x1536 folios don't look good or perform well on the iPad 1 / 2. By design, 2048x1536 folios don't show up on iPad SD devices -- only iPad HD. You've figured out one of the two ways to get a 2048x1536 folio on an iPad SD -- the other method is to create a single-issue development app with an embedded 2048 folio.
    Are you creating a single-issue app or a multi-issue app? If single-issue, your best bet is to create a 1024x768 folio with PDF image format. If multi-issue, create renditions.
    Jul 12, 2012 4:25 PM   in reply to mitchiedog
    Overlays are always rasterized. Smooth scrolling will only be exported as PDF with a length equal to or less than two pages.
    Bob
