Hi there, is anyone experiencing Illustrator crashing on startup, and more importantly, solved the problem? I am running OSX 10.6.8, have set permssions to everyone, repaired disk permissions via Disk Utilities - but it still crashes. Any other ideas much appreciated.
- Pete
Please perform steps 1-4, if it did work before mostly step 4 can solve your issue:
http://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-f reezes-mac.html
The Illustrator preferences file manages the commands and panel settings in Illustrator. When you open Illustrator, the positioning of panels and commands are stored in the Illustrator preferences file. If you want to restore the default settings for Illustrator or change the current settings, delete the Illustrator preferences. Illustrator automatically creates a preference file, when you restart Illustrator and save a file.
Please rename the directory:
<startup drive>/Users/<username>/Library/Preferences/Adobe Illustrator CS5 Settings/en_US*/
Well, I finally resolved this and I think its a font issue. In font book I cleaned up the questionable fonts, then I turned off all the user fonts, restarted in safe mode to clear the cashe, then retarted again normally and it is working. I went through and slowly added fonts and so far haven't found the corrupt one but Illustrator is still running fine. I have the fonts I really need and I still have the entire collection but they are not running. Hope this helps others.
