papejl
Unable to install Flash Player
Jul 11, 2012 8:43 PM
Hello, I am unable to install Flash Player.  I am getting the error: A Required File (c:\\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_ActiveX exe.5) could not be written due to insufficient permissions.
I have admin permissions.  This is a Windows 7/IE 9 config.  I need flash player to support an online exam and I am running out of time.   It appears to me there is an installer problem.  Please help and provide instructions how to work around or find patch.
    Jul 11, 2012 10:41 PM   in reply to papejl
    Try a clean install as described in http://forums.adobe.com/thread/928315
    If that does not work, you may have a permission problem in your Flash folders; see http://forums.adobe.com/thread/987370
    [topic moved to Flash Player forum]
    Jul 12, 2012 7:33 PM   in reply to papejl
    This is a public forum; please do not post your email address and other private data (by sending the entire forum notification message back to the forum).
    Jul 13, 2012 1:41 AM   in reply to Pat Willener
    Could you please try the following:
    1. Uninstall Flash Player. http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows. html
    2. Ensure that you delete the installation files and restarted the machine.
    3. Get the installer from http://www.adobe.com/products/flashplayer/distribution3.html
    4. Close browsers and install the installer.
    Sunil
    Jul 13, 2012 6:39 PM   in reply to papejl
    I am having difficulties understanding what is going on.  You are still getting that original message "A Required File (c:\\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_ActiveX exe.5) could not be written due to insufficient permissions" ?
    If that is the case, then
    1. you are not installing as an Administrator user
    2. have not executed the procedure http://forums.adobe.com/thread/928315
    3. have not executed the procedure http://forums.adobe.com/thread/987370
    Question: after you run the installer, is that module (C:\\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_265_ActiveX .exe) present?
    Jul 14, 2012 7:48 PM   in reply to papejl
    At this stage, in order to try to understand what is going on, I really need to know what files are in folder C:\\Windows\system32\Macromed\Flash
    papejl wrote:
    The non-active X version does not work for me
    Can you be a little bit more specific what you mean by that?
    → The ActiveX version is the Flash Player add-on for Internet Explorer; the plugin version is the add-on for all other browsers.
    Jul 17, 2012 6:23 PM   in reply to papejl
    So everything is fine now?
