Move video frame with cue point in same video frame
Jul 12, 2012 4:07 PM
Hello,
I know this is a strange one.  I have an animated project in cs4 as2.  It involves an flv video that is on a keyframe on my timeline.  I have been using cue points to go to frames to make text and objects appear and move.  I would like to sync my video to move at the same time as the animation.  This is difficult because I can't see it in real time.  I was wondering if there was a way that I could have my video play and when it gets to the cue point it moves to the frame I need that I have a background that is tweening to another position and at the same time actually have the frame with the video move.  This way I could keep my video still in one position and then move the frame with the background so the timing would be right.
So, what I want to do is use a cue point in my video to move the timeline to another frame and while playing the video in the frame, move it the same distance as the tween.
Is it possible?
Thanks for your help.
Mark.
    Jul 12, 2012 9:50 PM   in reply to MARKARKARK
    Really having a hard time following you here...afraid we need more info.
    Is your
    embedded into the main timeline or are you using a FLVPlayback component or are you using NetStream to play the video?
    How did you insert the cue points? are they navigation or event?
    What does that mean? move the location of the video? or jump to some other point in the video? and in relation to what?
    And you really lost me here...
    Please break it down into very small sections and give very precise details about each.
    Best wishes,
    Adninjastrator
    Jul 13, 2012 10:23 AM   in reply to MARKARKARK
    Are you saying that you want the video screen to move over to the right? or does the character turn and walk over to the right but the video screen doesn't move at all?
    What have you tried so far?
    Adninjastrator
    Jul 13, 2012 12:19 PM   in reply to MARKARKARK
    Then move the video player from point A to point B (insert new key frame there) and motion tween beteen the two locations.
    Treat the video player just like any other object on the stage.
    Jul 13, 2012 1:41 PM   in reply to MARKARKARK
    If the background is already moving, are you sure that you also need your character moving? The illusion of movement will already be there.
    If you do want to move the video player, you should do it using actionscript.
    Google "how to move object on flash stage with actionscript".. depending on whether you are using AS2 or AS3:
    http://www.youtube.com/watch?v=LhkI2zcMX6w
    or
    http://www.kirupa.com/developer/mx/ASmovement.htm
    etc... Google for more info.
    For development purposes, replace the video player with just a plain rectangle shaped object with the same dimensions as the video player. Practice moving the rectangle with actionscript before you attempt to move the video player.
    Once you can move as desired, then use the event cue point to fire the actionscipt and move the video player.
    But break this down into small steps. Get each small part working separately before you tie them all together.
    Adninjastrator
    Jul 18, 2012 11:19 PM   in reply to MARKARKARK
    Hello MARKARKARK,
    Could you please confirm if the solution worked for you?
    Suhas Yogin
