Using extreme large font
Avatar
Level 1
Hi all,
I'm working on a form which has a title with a very large font size. In the design view I have entered that it should be 120 large. Whenever I switch to PDF view, the font gets resized to a small value like 12. I f I select a value of 72 then in the deisgn view I can see the configured value.
Is there a limitation to the maximum size of the font I can use ? ( Helvetica Neue LT STD )
Avatar
Level 10
I'm not sure what's the problem at your end.
I had not problems using that font in a text and I could enter a size between 1 - 999.
What happens when you open the form in Acrobat or Reader instead of the preview?
Avatar
Level 1
Tx for reply.
Same thing happens in the end result PDF in Reader. The font size is adjusted in the form view, there I can indeed adjust to 999 but when I do that ( or in my case 120 ), the preview and now also the actual PDF show it as smal font.
