CQ5
Rollout results in error
Jul 9, 2012 9:51 PM
Tags: #sling #cq5.4 #msm #rollout
I am using CQ 5.4 MSM to create live copies out of master site. I am not using blueprint page approach here. So I use
New -> New live copy option.
I noticed that while trying to rollout changes made in the master site to multiple livecopies resulted in an error. So while rolling out changes to 3 live copies, only two were updated and the third threw the following error.
Caused by: javax.jcr.InvalidItemStateException: property /content/site/en/student/jcr:content/par/media/jcr:lastModified: the property cannot be saved because it has been modified externally.
    at org.apache.jackrabbit.core.PropertyImpl.makePersistent(PropertyImpl.j ava:155)
    at org.apache.jackrabbit.core.ItemSaveOperation.persistTransientItems(It emSaveOperation.java:835)
    at org.apache.jackrabbit.core.ItemSaveOperation.perform(ItemSaveOperatio n.java:243)
    at org.apache.jackrabbit.core.session.SessionState.perform(SessionState. java:200)
    at org.apache.jackrabbit.core.ItemImpl.perform(ItemImpl.java:91)
    at org.apache.jackrabbit.core.ItemImpl.save(ItemImpl.java:329)
    at org.apache.jackrabbit.core.session.SessionSaveOperation.perform(Sessi onSaveOperation.java:42)
    at org.apache.jackrabbit.core.SessionImpl.perform(SessionImpl.java:355)
    at org.apache.jackrabbit.core.SessionImpl.save(SessionImpl.java:758)
    at com.day.crx.core.CRXSessionImpl.save(CRXSessionImpl.java:126)
    at com.day.cq.wcm.msm.impl.RolloutManagerImpl.executePageRollout(Rollout ManagerImpl.java:494)
    ... 62 more
I've tried rolling out via sidekick and MSM control center and get the same error. Rolling out changes to a single livecopy works as expected without any error.
In some other posts I came across, it was mentioned that it might be a Sling issue while trying to modify multiple nodes? If so how to resolve this? Has Adobe provided a hotfix for this?
Any pointers on this? Am I missing something here?
- Ashish
    Jul 10, 2012 3:55 PM   in reply to AshishPanwar
    Hi Ashish,
      Though i do not have complete logs seems like you are hitting an know issue.   Please follow [1] as a temporary workaround to fix. This issue is resolved in CQ5.5.
    [1]
    * Go to /system/console/configMgr/com.day.cq.wcm.msm.impl.RolloutManagerImpl web app and login as admin
    * Add "jcr:lastModified" under the "Excluded Paragraph Properties"
    * Save
    * if that configuration fixed the problem then make the same configuration at the repository level under apps using a sling:OsgiConfig
    Sham
