Hi
Why Adobe Acrobat Pro disables comments & markup tools for PDF/A documents ?
Arvind
we are not editing the file - we are annotating it.
annotations are saved as separate objects (files) that are associated with the original. the original is never changed
how does a plugin switch off this behaviour so that we can set our own usage policies and address the needs of our customers?
oh, ok. So what you are saying is that the core API will disable *any* write to the in-memory pdf if it is of pdf/a format.
Is this the same for the client plugin API and the livecycle server api? i believe that our livecycle server managed to assign reader-rights to the pdf/a document, which sounds like it shouldnt be able to do. Is that a bug?
It's doesn't disable the lowest level changes – but it does make the PDF appear as "read only" to higher level APIs (such as AddAnnot).
You can assign rights to a PDF/A, but it wouldn't matter since as long as it's PDF, it can't be commented on.. If you remove the PDF/A compliance, then it can.
