Hi I have installed numerous times the debug player for firefox and also for IE.
But still the regular player is running in the browsers? I uninstalled all players with the uninstall tool but still I get no debug player running in my browser. This way I can't debug my application.
Does anybody know why the player is still the regular one and not the debug player after installing the debug player version?
And does anybody has a solution for it? Is there maybe something I need to do during uninstall or something because until now I have no idea what to do further.
Kind regards.
From where are you downloading the debug players? (Here is the URL: http://www.adobe.com/support/flashplayer/downloads.html)
Please go to the following page: http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html# main_Find_Flash_Player_version_type_and_capabilities__Flash_developers _only_
After installing the debug version, does the flash movie in the site above display "Debug Player: No"?
Sunil
Hi Sunil thanks for taking the time.
1. I installed it from the page you mentioning above.
2. Checked on the page if it says no or yes. It says YES.
However when I right click on SWF movie it doesn't show me it's the debug player.
If I am correct it did show if it was the debug player in previous versions when you right clicked.
I also made a test SWF that throws an Error when I click on the stage, the player also doesn't throw me a popup window with this error so for sure I know debug player is not running!
What's your SWF development environment? Flash Builder, Flash Professional?
I think these applications handle the debugger differently.
Can you please try the following:
Go to C:\WINDOWS\system32\Macromed\Flash. (on 64-bit: C:\Windows\SysWOW64\Macromed\Flash)
Open the mms.cfg file.
Add the following entries:
ErrorReportingEnable=1
TraceOutputFileEnable=1
MaxWarnings=50
Now try to run the SWF file.
Go to the location mentioned above and open the flashlog.txt created.
See if it logs errors.
More info: http://helpx.adobe.com/flash-player/kb/configure-debugger-version-flas h-player.html
Sunil
In this case for testing I am just using Adobe Flash Pro CS5.5 and by hitting the Ctrl+F12 button I export and can directly test it in the browser but doing this, it doesn't show any Error windows apparently. However i checked the log file and it is recording the error's I have created on purpose.
So yes it seems to be working but it's not throwing any popup window with error's, It would be nice if it showed me the error windows if there is a error. So I guess debugger was always working only not showing the Error window.
How can i fiks this?
Thanks until so far Sunil ![]()
I found out what was wrong, A view months ago I installed FlashFireBug to see what it does, maybe something went wrong during un-install of this FlashFireBug after I was ready with it. So what I did is re-install FlashFireBug and run the test html page witch throws a error, and there was my DialogBox with my error.
I uninstalled FlashFireBug and after that it still shows me the DialogBox with my error.
I noticed something, in the error log about it.
It couldn't find something from FlashFireBug that was installed as a Add-on. unfortunately I don't have the output string anymore of this error.
So re-installing this FlashFireBug add-on and un-installing it again worked for me.
Thanks for all the help.
