Using the "Edit In" option to open an image from LR 4.1 in Photoshop CS6 where it will have the "Oil Paint" filter applied. The resulting image when saved does not show up in the LR 4.1 collection from which the original came. The file itself is save to the disk but unlike other times when the "Edit In" feature has been used the resultant image is not made part of the Collection. Has anyone else seen this problem?
The normal "Edit in Photoshop" method should have automatically imported the newly saved image, into Lightroom, without needing to Sync the folder.
However, this does not necessarily mean that this new image will immediately show in the same Collection, Smart collection, filmstrip view or grid view as the starting image does; or even if it does, it may not appear next to the starting image.
That is all merely a question, of how exactly you are viewing the image library at this given moment, and of what attributes and properties the various image versions have, which are relevant to that. The original and the edited versions filter, select, sort, have membership in Collections, etc independently.
Also these two may (and will by default) be involved in a stack - so one or the other gets sometimes concealed from view due to that.
For the Photoshop edited version to be placed automtically back into a collection the user must first have sent the original to Photoshop from within that collection. Sending it to Photoshop from within a folder means that edited version it will not be placed into a collection, irrespective of whether the original was in one or not.
Ian Lyons wrote:For the Photoshop edited version to be placed automtically back into a collection the user must first have sent the original to Photoshop from within that collection. Sending it to Photoshop from within a folder means that edited version it will not be placed into a collection, irrespective of whether the original was in one or not.
I wasn't aware of that extra subtlety - thanks. I suppose it's logical enough once you know about it
So perhaps the OP might have used Edit In.. from a folder based view in this case, and from a collection based view on earlier occasions?
Actually it turned out that only after doing a "SAVE AS" rather than the usual "SAVE" was I able to get the edited image to appear in the DEVELOP and LIBRARY modes for that particular image's COLLECTION. As for the STACKING it was not in play.
I use the filters in ACTIONS and it turns out that the "OIL PAINT" filter seems to be fraught with this problem. None of the others that I have used seem to demonstrate this error.
I tried the SYNCHRONIZE option when the folder was selected and after an attempt it told me that there were no images that needed this? So evidently the edited images I created are somehow "attached" to the COLLECTION but are not showing up when in either DEVELOP or LIBRARY modes.
I wonder if this is something that the LR 4.1 team could verify as a bug or not?
I believe that your edited image is represented in the Catalog, and that this will happen when you Save in PS. I don't see how it would be happening if you use Save As in PS.
If you know it is represented in the Catalog, but you are not seeing it, I would first go to "show folder in Library" on the original image version and see what is in there too. Then check this is not a filtered view: press \ key for the Library Filter bar, and choose "none". Then (if there are a lot of images in the folder) check your sort order - sorting by capture date/time should put the edit and the original right next to each other. Then I'd double-check for stacking; it is the default (IIRC) for LR to do that automatically.
Something else that might be helpfully. There is a preference in photoshop that toggles all "save as" files to be saved to the parent file. Otherwise it goes to the last used location be default. In my workflow, all the "edit in photoshop" files sow up in the catalogue, but any "save as" versions need the synchronizing click to show up.
