Alex DeJesus 452 posts
Jul 25, 2008
Project Exceeds Disk Capacity - What Do I Do?
Jul 12, 2012 9:41 PM
4.87 GB is the current size. Is there a way to make Encore automatically adjust data rate to fit on a DVD disk without editing out part of the video?
I changed the project transcode settings from 8 to 6 Mbps, but it did not make a difference in the projected project size. I also changed the quality preset values, but that didn't make a difference, either.
    Jul 13, 2012 7:31 AM   in reply to Alex DeJesus
    Tell Encore you want to use a dual layer disc... if, of course, you HAVE a dual layer burner and disc blanks
    Also, to create a dual layer disc, you MUST do this http://forums.adobe.com/thread/969395
    Jul 13, 2012 7:36 AM   in reply to John T Smith
    If you don't want to go dual layer,  you must "revert to original" to retranscode. When you can't select a new setting, that is usually what has happened.
    Jul 13, 2012 10:01 AM   in reply to Alex DeJesus
    I just thought there was a setting that automatically encoded the disk to max 4.7 capacity.
    There is; set the transcode setting to "automatic."
    I thought you saw that and could not get it to stick. But you want to use that on a lossless or minimally compressed file, or by using dynamic link; not on material that is already mpeg2.
    Jul 13, 2012 11:54 AM   in reply to Alex DeJesus
    As Stan said, there is such a setting inside Encore... I always use that setting, with DV AVI exported out of PPro, so Encore is able to do the transcoding
