Optimizing images | Learn Dreamweaver CS6 | Adobe TV
Jul 11, 2012 8:55 AM
    Jul 11, 2012 8:55 AM   in reply to Community Help
    The drag and drop functionality does not seem to be working in Design view.  I have to be in Code view to get the drag and drop to work with the images.  Sort of defeats the purpose.
    Jul 11, 2012 11:39 AM   in reply to warlock7
    warlock7,
    I tested this out in Dreamweaver CS6, but in all cases the drag-and-drop was functioning properly.
    If you create a new document using one of the included layouts (e.g. 3-column liquid) and insert an image in it, are you able to drag it around?
    Jul 11, 2012 12:00 PM   in reply to Carey Burgess
    I believe that it might be due to the fact that I'm using XHTML strict.  To test it out I created a new page and was able to use the drag-and-drop functionality, so I'm not positive what the reason.  Is there a limitation when writing XHTML pages?
    Jul 13, 2012 8:11 AM   in reply to Carey Burgess
    Is that functionality limited to the provided templates?
    I am also still curious if it works with XHTML or not?
    Jul 25, 2012 12:57 PM   in reply to Carey Burgess
    Wow, great support there Carey.  Why answer the question then not respond again?!?!  I found your software to not work as described.  Then you tell me that it does and never follow up again?  I've asked follow up questions and you haven't replied for over two weeks.
