drop down menu does not work for user
Jun 19, 2012 10:39 AM
Tags: #spry #dropdown_with_links
I  have a spry drop down menu in the website http://www.ituna.ca and I have just been informed by a user that she is unable to use the menu as a drop down.  This comes as a surprise to me as I have used it successfully in many different browsers and many computers and even the ipad ... so if she is having an issue, perhaps other people are as well.
Is there something I should have done differently or is there something I can tell the user to do to allow use of the menu?
Pat
    Jun 29, 2012 2:02 PM   in reply to nehsurk
    Pat,
    Your menus look fine on my system, too. It is possible that your user is working on a system with javascript turned off, either on her own computer or, if she is in a company, turned off by the network administrator. Ask her how she is viewing your website...laptop, desktop, smartphone, tablet, etc., to help you pinpoint what your solution will be.
         If her javascript is turned off (not to be turned on...), one strategy around this is to create pages linked to your top level menu items. On those pages, you can make text links (not dropdowns) to the menu items that show on the drop-downs. This could be paired with the next idea, as a sort of belt-and-suspenders solution.
        A less obtrusive way: Add a secondary, substitute text menu that only appears when javascript is turned off by using <noscript> </noscript> tags around the secondary menus.
         Be wary of solutions that require you to tell different users different things.
    Beth
    Jul 10, 2012 1:15 PM   in reply to nehsurk
    Sure thing. Good to duplicate menu links; as long as people can get where they need to go, they don't need dropdowns, anyway. The trick is not to make the lack of drop-downs an obvious omission or lack. You have done the duplicates, so you should be fine.
    Beth
    Jul 12, 2012 8:23 PM   in reply to Zabeth69
    Beth,
    I have a follow up question to this issue. While I can use the <no script> </no script> code to create submenus say, across the top of my page, where I'd really like for them to appear is underneath my top level menu items in my left menu bar. So if JavaScript is turned off, they show up. If it is turned on, my spry nav menu functions properly. Is there an easy way to do this?
    Gail
    Jul 13, 2012 7:43 AM   in reply to gbergan52
    Why not just put them there? Take the whole lot, <no script> tags and all, and place them directly under the main menus.
    Beth
    Jul 13, 2012 8:00 AM   in reply to Zabeth69
    By messing with the code inside the Spry menu, it wouldn’t mess up the functioning of it at all? Thanks for your help,
    Gail
    Jul 13, 2012 8:28 AM   in reply to gbergan52
    Don't mess with the Spry menu code AT ALL. And don't put anything BETWEEN </li> and <li> or </li> and </ul>. That will not work well.
    Put it below the </ul> at the end of the menu code.
    Beth
    Jul 13, 2012 8:30 AM   in reply to Zabeth69
    OK, thanks, I’ll give that a try and let you know how it works. Thanks!
    Gail
    Gail R. Bergan, President
    Bergan et al., Inc.
    413 So. Church St.
    Rockport, TX 78382
    361-727-2343
    www.bergan.com
    www.google.com/profiles/gailbergan7
    www.linkedin.com/pub/gail-bergan/30/aa6/391
