Andreas.Koch
Support of Reader & Acrobat in parallel
Jul 12, 2012 2:10 AM
Hi there,
as far as I know a parallel installation of Reader and Acrobat on one single PC was not supported by Adobe in times of Version 8 and earlier.
Is this still the case for Version 10?
In the past we got many issues reported regarding the parallel usage of there two applications and we need to know if we have to uninstall the automatically installed Reader if a user is requesting the installation of Acrobat.
Is there something official from Adobe regarding the support of this scenario?
Andreas
    Jul 12, 2012 6:55 AM   in reply to Andreas.Koch
    Looks like there is but it needs to be updated for Acrobat and Reader X.
    http://helpx.adobe.com/acrobat/kb/problems-installing-removing-acrobat -reader.html
  • David Kastendick
    Apr 7, 2010
    Jul 13, 2012 9:38 AM   in reply to Andreas.Koch
    Hi Andreas,
    With the Acrobat X/Adobe Reader X release, we now support having both Acrobat & Reader on the same machine: http://blogs.adobe.com/pdfitmatters/2011/03/installing-acrobat-x-and-r eader-x-on-the-same-machine.html
    Previously, while it was possible to parallel versions (Acro 9 & Reader 9) installed on the same computer, it was not a supported configuration.
    We do not support having multiple versions on the same machine (for example: Acro 8 & Acro 9 or Acro 7 & Reader 9).
    Please let us know if you have any questions.
    -David
  • David Kastendick
    Apr 7, 2010
    Jul 17, 2012 2:36 PM   in reply to Andreas.Koch
    Hi Andreas,
    Is my understanding of your article correct that we should remove Adobe Reader if Acrobat will be installed with every newer version then X?
    If the version of Reader is 9 or earlier, yes, it should be removed.  If the installed version of Reader is Reader X, it's up to you as to whether or not to leave it installed.  I would recommend installing only Acrobat unless your user has a need for having Reader installed too.
    But even with a parallel installation of the X versions of both I see some issues here at my company. We have applications in use (e.g. Documentum), where it is necessary that the PDF will be opened in a browser with Acrobat for annotations and comments. How can I influence this if the user selected Reader as default viewer in the Customization Wizard. We can not handle this Wizard one more then 5k PC's manually.
    If you're creating an MST w/ the Customization Wizard, Acrobat will default to snagging default viewer status.  Here's a thread that discusses when someone desires the opposite behavior, but I think you might find it useful: http://forums.adobe.com/message/4458544  You should also check out Page 34 of the Acrobat Enterprise Administration Guide: http://helpx.adobe.com/content/dam/kb/en/837/cpsid_83709/attachments/A crobat_Enterprise_Administration.pdf
    Would it then be a possible way to also remove Reader X version from PC's where Acrobat is goind to be installed to prevent this issue? even if the parallel usage of version X is supported by Adobe?
    See http://forums.adobe.com/message/4206151 for more information about this.
    Let us know if you have any other questions!
    -David
