PeptoBismolMonk
Need help with sum of 2 fields minus 1 field
Jul 13, 2012 9:09 AM
Hello,
I have been trying to obtain a total difference between 3 fields to be formulated for my final field at the bottom of my document.
Here is an example since the document is on a secure network.
Example:
Field 1 - (Field 2 + Field 3) = Total Difference (in my case I want this to equal Zero)
I have tried multiple different custom formulas but so far either get a syntax error with script or it allows the script to be entered but the will not work once I begin to fill out the form to test out all of its applications.
so far I have found:
[Field# merely where the real title would be placed]
var v1 = getField("Field1").value;
var v2 = getField("Field2").value;
event.value = v1 - v2;
This formula I believed would work but even without restructing it to fit my own requirements this formula did not gather any information nor caluclate it but merely left a big old Zero in the section I wanted the fields calculated difference to be entered in.
Any help with this issue would be greatly appreciated.
  • George Johnson
    Aug 11, 2002
    Jul 13, 2012 9:42 AM   in reply to PeptoBismolMonk
    To use the simplified field notation option, be sure there are no spaces in the field names and the following should work:
    Field1 - Field2 - Field3
    The following custom Calculate script should do the same thing:
    (function () {
        var v1 = +getField("Field1").value;
        var v2 = +getField("Field2").value;
        var v3 = +getField("Field3").value;
        event.value = v1 - v2 - v3;
    Also, be sure that the field calculation order is correct. If you don't know what this is, post again.
