Workaround for using Warp stabilizer with Speed change in CS6
Jul 13, 2012 11:32 AM
Tags: #premiere #export #cs6
Hi there, I need to slow down a clip AND apply some Warp Stabilizer on it, but Premiere CS6 will not let the 2 effects happen on the same clip. So as a work around I am thinking that I should stabilize the clip, render and export it. Then use that new clip in timeline and change speed.
Is this the best way to do it?  Better than stabilizing in AE and back, I hope....
And if so, in order to maintain the best quality of the clip, what format should I export the clip into? (my footages are from a Canon 5Diii, native H.264)
I suppose I should use 'File>export>media' and set the quality to max and use 'Max render quality'.
Thanks very much!
    Jul 13, 2012 12:10 PM   in reply to khw8911
    Could you nest your clip, apply the stabilizer then step out of your nest and warp that?
    Not able to try myself first, not in front of edit computer. Thats why I'm not 100% sure about my solution. Let me know if it works for you.
    Pete
    Jul 13, 2012 12:55 PM   in reply to khw8911
    Apply the effects, nest and finally apply Warp Stabilize.
    That should do the trick.
    Jul 13, 2012 1:22 PM   in reply to Ann Bens
    Haaaa, Thanks Ann for correcting my backwords reply.....I was thinking like you, just couldn't type it in the correct order.
    Jul 13, 2012 1:49 PM   in reply to khw8911
    I would create the intermediate but not sure in which order.
    Maybe stabilise first because its a shorter clip ...then speed warp it.
