AgentFiveSevenFive
My quick mask went grayscale...how to fix?
Jul 13, 2012 6:36 PM
I don't think I did anything but now when I click to add a layer mask and then the gradient tool, the colors are no longer allowed.  Someone know how to fix this?
  • JJMack
    Jan 9, 2006
    Jul 13, 2012 6:39 PM   in reply to AgentFiveSevenFive
    When you add a layer mask it becomes the photoshop target Layer mask are grayscale
  • JJMack
    Jan 9, 2006
    Jul 13, 2012 8:42 PM   in reply to AgentFiveSevenFive
    I may have miss understood what you wrote. The gradient tool itself should show colors in its option bar and you should be able to select color gradients. It just when you draw out one and apply it when a layer mask is the target the results will be a grayscale for layer mask are a grayscale thing.
    If the tool itself is only showing grayscale gradients try resetting the gradent tool to the defaut gradents or some other set other then the neutral density set which are all grayscale..
  • Noel Carboni
    Dec 23, 2006
    Jul 13, 2012 10:50 PM   in reply to AgentFiveSevenFive
    You wouldn't happen to have created a grayscale document instead of RGB, would you?  I know that's a pretty basic thing, but sometimes we don't look at the defaults in the File New dialog.   Image - Mode - RGB...
    -Noel
  • JJMack
    Jan 9, 2006
    Jul 15, 2012 6:24 PM   in reply to AgentFiveSevenFive
    Have you tried resetting your Photoshop preferences?
    Jul 15, 2012 7:33 PM   in reply to AgentFiveSevenFive
    "I am confused because I have literally done this hundreds of times...the layer mask is selected and yet the gradient will not be grayscale...and now it is."
    Yes. You are confused. Layer mask is, and always has been, grayscale.
  • JJMack
    Jan 9, 2006
    Jul 15, 2012 8:06 PM   in reply to AgentFiveSevenFive
    AgentFiveSevenFive wrote:
    no.
    Preferences > Reset All Warning Dialogs?
    Will everything be reset?  Plugins and brushes and such?
    Not everything will be changed thing that you added will still be on you system like brushes presets actions etc.  However thing settings will be reset to Photoshop defailts like action sets you have loaded will not be loaded.  You will need to load them again.  If you installed plugin into you own Plug-in folder structure and added that folder to Photoshop preferencess you will need to edit you reset preferences and make the changes you make changes to the defaullts like adding an additional plug-in path, open images in floating windows not tabs, Things like Screen DPI resolution increase number of history states etc.
    Resetting Photoshop prefences often fixes Problems when Photosho's starts acting strang like tools not working like normally.
    When you click Quick Mask Photoshop overlays the image with a color overlay mask the default color is red however this is changeable. Did you by chance douple click on the quick mask icon and change the option from red to gray sometime in the past?
  • JJMack
    Jan 9, 2006
    Jul 15, 2012 8:58 PM   in reply to AgentFiveSevenFive
    Note: If you ever need to reset Photoshop preferences to the default settings, press and hold Shift+Option+Command (Mac OS) or Shift+Alt+Control (Windows) when you start up Photoshop. Be sure to press and hold these keys before the startup screen appears. It will ask if you want to delete the preferences file. To reset Photoshop to its default settings, click Yes.
    Jul 15, 2012 9:18 PM   in reply to AgentFiveSevenFive
    No, you don't want to do anything to the dialog boxes.  It's the Photoshop Preferences files you want to trash, delete, nuke and re-set.
    Hold down Control+Alt+Shift (Windows) or Comand+Option+Shift on a Mac as you launch Photoshop.  You'll get this dialog box:
    …I am so confused at how all of a sudden something that worked for years is gone.
    When things suddenly go weird in Photoshop, that's a clear sign that your Photoshop preferences got corrupted.  That's why you need to trash and re-set them.
    Jul 15, 2012 9:03 PM   in reply to JJMack
    JJMack typed faster, while I was embedding the screen shot.
  • PECourtejoie
    Jan 11, 2006
    Jul 16, 2012 5:25 AM   in reply to AgentFiveSevenFive
    Hello!
    Before you reset the preferences, do try to double-click the quickmask button to check if black is not selected instead of read.
    (you can also get to it you enter the Channel Panel's menu, and select Quick Mask Options.)
  • PECourtejoie
    Jan 11, 2006
    Jul 16, 2012 5:31 AM   in reply to PECourtejoie
    Agent Seven five, in the discussion, you seem to interchange quickmask and layer mask, they are not the same thing.
    Quickmask, also called rubilith is a way to paint/draw your selection. You activate it with the letter Q, or by clicking on the icon below the color wells in the tool panel.
    A layer mask is a non-destructive way to show/hide parts of a layer using black and white.You create one with the black and white button at the bottom of the layers panel.
    Note that you can use quickmask on a layer mask, if you need to select an area before editing it with a filter/gradient, etc.
    Make sure you are using the correct terminology, you'll get more accurate answers that way.
  • JJMack
    Jan 9, 2006
    Jul 17, 2012 9:59 AM   in reply to AgentFiveSevenFive
    When you click that button in the layers palette a layer mask will be added to the  currently targeted layer and become the current Photoshop target.  The contents of the layer masks depends on the conditions that existed when you click the add layer mask icon button.  If there was no active selection and no keys were held down it will be all white a reveal all layer mask. If no selection and you held down the Alt/Option key the layer mask would be all black a hide all layer mask.  If there was a selection like a luminosity selection active when you click the icon with no keys held the layer mask added would look like a grayscale of you image. Had you held down the Alt/option key the layer mask would look like a negative of your image.
    After adding the layer mask it will be the current Photoshop Target. You can select the gradient tool and select a colored gradient as the gradient to use. However when you drag out its path and apply it the gradient applied will be a grayscale version for Layer mask are grayscale.
    Jul 17, 2012 10:23 AM   in reply to AgentFiveSevenFive
    What I was doing before was clicking the layer mask button at the bottom of the layers panel and then I swear I was able to select the gradient tool and was not held to black/white/gray but now I am.
    Nope.
    You can view a Layer Mask as rubylith by hitting the backslash key. But the layer mask is, and was, grayscale.
  • Noel Carboni
    Dec 23, 2006
    Jul 17, 2012 12:28 PM   in reply to AgentFiveSevenFive
    I must have imagined the last couple years.
    The phrase I've always liked is "I've slept since then".
    And I'll confirm that it's never been possible to have a colored layer mask.
    -Noel
