I have two text boxes
1. First text box is defaulted to the curent date + 5 business days.
2. When i pick the date from the second text box, I want the date in the fisrt text box = date in second text box + 5 business days.
The code i have below is currently working fine but the fist fidn't added 5 business days because i don't know how to add into it from txt2.
How can I accomplish it?
<!---cfm--->
<cfparam name="currentdate" default="#businessDaysAdd(now(),5))#">
<cfform name="fform">
txt1: <cfinput type="datefield" value="#dateformat(current, "mm/dd/yyyy")#" name="txt1" bind="cfc:app.home.cfc.bu.getfinaldate({txt2@change})">
txt2: <cfinput type="datefield" name="txt2" value="">
</cfform>
<!---cfc--->
</cfcomponent>
<cffunction name="getfinaldate" access="remote">
<cfargument name="txt2">
<cfreturn "#arguments.txt2#">
</cffunction>
</cfcomponent>
In your cfc, use parsedate to convert the text to a date, then use dateadd to add the five days and dateformat to convert it back to a string.
Note you have a typo: 2 closing component tags. In any case, the following should work
<!--- Set bindOnload to yes, making the bind to take effect the moment the page is loaded. --->
<cfinput type="datefield" name="txt1" bind="cfc:app.home.cfc.bu.getFinalDate({txt2})" bindOnload="yes">
<cfinput type="datefield" name="txt2">
</cfform>
bu.cfc
<cfcomponent>
<cffunction name="getFinalDate" access="remote" returntype="string">
<cfargument name="dateArg">
<!--- If argument undefined or not a date, then default to date of today --->
<cfif (not isDefined("arguments.dateArg")) or (not isDate(arguments.dateArg))>
<cfset var dt = now()>
<cfelse>
<cfset var dt = parseDateTime(arguments.dateArg)>
</cfif>
<!--- Add 5 days--->
<cfset var updatedDt = dateAdd("d",5,dt)>
<!--- Format --->
<cfset var formattedDt = dateformat(updatedDt, "mm/dd/yyyy")>
<cfreturn formattedDt>
</cffunction>
</cfcomponent>
