RedLinda
How do I prevent automatic caption of OLYMPUS DIGITAL CAMERA?
Jul 14, 2012 2:33 AM
Tags: #mac #metadata #4.1
The caption field of Metadata automatically fills with OLYMPUS DIGITAL CAMERA.  How can I prevent this?  How can I get rid of this on my 3000 pictures of Turkey without manually deleting each caption?  I am new to Lightroom, and have version 4.1.  I use an iMAC, OSX10.6.8.  Thanks.
    Jul 14, 2012 3:53 AM   in reply to RedLinda
    Select all the photos (Cmd-A), then go to the field where the caption is shown, and select the entire field and hit backspace.
    I have no idea why the field is filled with OLYMPUS DIGITAL CAMERA, as I don't own one. Nevertheless, as you can see it is easy to fix.
    Jul 14, 2012 10:10 AM   in reply to dj_paige
    Olympus writes it into the file at capture.
    Jul 14, 2012 10:24 AM   in reply to Seán McCormack
    Does that mean it'll still appear in every newly-imported file, Seán?
    Jul 14, 2012 10:37 AM   in reply to Keith_Reeder
    Does for me so far on both the E-PL1 and the OM-D E-M5..
    Jul 14, 2012 12:53 PM   in reply to RedLinda
    You should be able to remove it with an import template.
    Sent from phone.
    Jul 14, 2012 1:14 PM   in reply to RedLinda
    Well so far we only know that it's unwanted by you, Linda.
    Nothing automatically appears in the "caption" metadata fields for my Canon cameras, incidentally.
    Jul 15, 2012 4:43 AM   in reply to RedLinda
    RedLinda wrote:
    Do other camera manufacturers do this?
    My Konica Minolta 7D did. My Sony a77 does not. My wife's Canon IXUS 100 does not.
    I guess you can write something else into the Caption field on all your future imports by creating a Metadata Preset in the import dialog. I have not tested it, but the Caption field is one of the metadata fields which are handled by a Metadata Preset.
    Jul 15, 2012 5:42 AM   in reply to Allan_Olesen
    Some camera manufacturers do write the camera type in the caption :
    See this note by John R Ellis in his faqs for Elements:
    "Some camera manufacturers insert the name of the camera in the caption field of a photo’s metadata, and when you import the photo into PSE, it shows up as a caption.  To stop this from happening, uncheck the option Edit > Preferences > Files > Import EXIF Caption.  To remove the caption from photos that have already been imported:
    1. Do Find > By Caption Or Note and type in the name of the camera.
    2. Edit > Select All.
    3. Right-click one of the photos and select Add Caption To Selected Items.
    4. Leave the caption field blank, check Replace Existing Captions, and click OK."
    There must be an equivalent solution in LR ?
    Oct 2, 2012 8:08 PM   in reply to MichelBParis
    There is definitely a way to automatically remove "Olympus Digital Camera" from your captions...use a metadata preset.  (excuse the late reply to an old thread)
    In Lightroom 3 or 4, (and possibly earlier):
    1. Click Metadata...Edit Metadata Presets
    2. Check the box to the right of caption, but do not type anything into the box.
    3. Fill in whatever else you want.  I usually have my copyright, name and address stamped onto every image I import.
    4. At the top, click the "Preset" drop down box and click "Save Settings as a New Preset".  Type in a name, such as "standard copyright preset."
    5. When you import, set the Metadata preset to "standard copyright preset" or whatever you called it in step 4
    The annoying "Olympus Digital Camera" ITPC caption will be magically erased on import.
    Hope this helps!
