If preserve formatting isn't working (and there really is some formatting to preserve), how you get to the import options dialog won't matter. You might want to try trashing your preferences. See Replace Your Preferences
No, I did not clear prefs because my IDD is new, and the only thing I changed is "Clipboard Handling."
I don't see where to attach a file. I made two samples--one is RTF, and other is .odt.
Thank you for helping. (I don't want to buy a new copy of Office, which is what I used on by old computer)
There's no way to predict when prefs will become corrupt, so please do try that.
Attachments are disabled so you must post a link to a file hosted on some other system. One way to do that, if you don't have your server, is to use YouSendIt.com to send the file to yourself, then copy and paste the link here.
I deleted the prefs, reopened IDD (reset import options) and tried to PASTE or PLACE from RTF file. Didn't work. Then I saved my .odt file as OpenOffice (.docx), and I was able to PLACE with formatting. IDD does not "see" the OOo (.odt) file, so I cannot attempt to PLACE that. Looks like I chose the wrong open source suite. LibreOffice is apparently not compatible with IDD.
I am a volunteer layout person for a theatre, and now I must decide between a switch to OpenOffice or purchase a new version of MS Office. It looks like Word is more compatible with IDD.
Thank you very much for following through with me. Re: Adding text to frames
Joann
ID should have no problems with RTF from ANY application. I don't know how many users there are importing from OpenOffice/LibreOffice, but we don't hear a lot of problems, which makes me think the issue is something else on your system.
Import options only affect Placing. When you paste, the clipboard handling prefs kick in.
I have "All Information..." selected (radio button) in ID Clipboard prefs, and I just tried to PASTE text with italic titles from Mac Mail, and italics did not come thru. I then did the same thing on the old computer with CS3, pasting from the same email, and what should have been italic was not, but it was pink shaded--so I knew it was a font problem and when I changed font to Arial, the italics showed.
Something is not right in my SS5.5. I need to be able to paste with formatting.
I just tried a copy/paste from my website into frames in CS3 and 5.5, and the same thing happened: OK in CS3 and not in 5.5.
After testing with Indesign CS3/CS4 and an older OpenOffice 3 (3.2.0), I can confirm, that the issue is already there in CS3 (5.0.4) and InDesign CS4 (6.0.6) on Mac OSX 10.6.8. All software in German.
I tried several workarounds:
1.a Copy/Paste from OpenOffice to TextEdit => OK
1.b Copy/Paste from TextEdit to InDesign CS3/CS4 => FALSE
2. Save as .doc format out of TextEdit, place file in InDesign CS3/CS4 => OK
3. Save as .doc format out of OpenOffice, place file in InDesign CS3/CS4 => FALSE
4. Save as .rtf format out of TextEdit, place file in InDesign CS3/CS4 => FALSE
5. Save as .rtf format out of OpenOffice, place file in InDesign CS3/CS4 => FALSE
The used font was Times New Roman, also tried Adobe Caslon Pro, same thing.
In my OpenOffice 3.2 there is no option to save to .docx, though opening .docx files are possible.
I will try with the new version 3.4 and report back.
Uwe
@Peter – not yet.
I'll give myself another try with OpenOffice 3.4.
And testing with InDesign CS5, CS5.5 and CS6.
But no spare time today for this…
My solution with my combination of applications, so far, would be:
A. Copy/Paste from OpenOffice to TextEdit
B. Save as .doc format out of TextEdit
C. Place the .doc file
Uwe
For comparison, "new" system is Mac OS X 10.7.4, IDD CS 5.5, LibreOffice 3.5.3.2, TextEdit 1.7.1
"old" system is Mac OS X 10.4.11, IDD CS 3, Word 2004
"New Sys" Copy/Paste all FALSE (.odt, .RTF, Mail, html); Place from docx (saved from LibreOffice) TRUE; other Place's all FALSE
"Old Sys" Copy/Paste & Place all TRUE
Joann --Thanks for joining, Uwe
Followup to my copy/paste with formatting problem in CS5.5 [My "new system" is described in msg above 7/17.]
I just downloaded trial copy of MS Office, and copy/paste with formatting is works correctly from Word docs. I also opened files saved as RTF from LibreOffice, and formatted paste from them works also.
Caveat: installing MS Office messed up my LibreOffice files! Those files were fine yesterday; now I can OPEN them, but they're unreadable. After some panicked minutes, I SAVED them as TEXT out of LibreOffice and opened them in Word/Excel and they're fine.
CONCLUSION: As of now, LibreOffice and InDesign are not compatible.
Thanks to everyone who helped.
