Mercury Playback Engine Bug Discovered
Jul 14, 2012 11:53 AM
Tags: #color #shift
Hello,
I'm color correcting XDCAM EX mp4 quicktimes of talent in front of a white screen using RGB curves and after I export an h264 the color shifts dramatically. The white screen in the background becomes blue.  I tried switching to software acceleration and things export as expected.  CS 6, 2010 MacPro, Lion, Quadro 4000.  I'm on a deadline and would appreciate any help.
Thanks!!
Gerry
    Jul 14, 2012 12:26 PM   in reply to digitalkiln
    This is probably not a bug, but the result of the way GPU acceleration handles light, which is different from the software mode.
    If that's right, there's little you can do here but continue in software mode.
    Jul 14, 2012 12:29 PM   in reply to digitalkiln
    So Adobe may test, send a detailed bug report to https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Jul 14, 2012 2:56 PM   in reply to digitalkiln
    It doesn't matter to me how they handle light
    Well, if that's the correct explanation (and I'm only theorizing it is), then it matters because your only fix is to turn off hardware acceleration.
    Jul 15, 2012 12:58 PM   in reply to digitalkiln
    Hey digitalkiln - would you be able to share a small sample project with media?
    Jul 16, 2012 10:06 PM   in reply to digitalkiln
    Did that mean the "issue" is no longer an issue and not repeatable?
    Jul 16, 2012 10:40 PM   in reply to digitalkiln
    I will take that as not a bug ...and of a  low to no  risk threat to myself.
    Jul 17, 2012 3:50 AM   in reply to digitalkiln
    Hey digitalkiln,
    If you find out the cause of the problem, I'm all ears.
