KO333
Can't install any CS6 apps. "Installer failed initialize."
Jul 14, 2012 11:44 AM
Tags: #problems_loading_software
Download of new CS6 noted as "sucesssful"; but I found no instructions for installation after unzipping.  I don't want to download again (it took 3 hours).  Are there any alternatives?
There apears to be some pieces of code missing.  Is there any way to determine what it is?
Do I need to uninstall the trial version of ID or my old version of Photoshop /elements 2.0?
    Jul 14, 2012 12:43 PM   in reply to KO333
    Which CS6 application/suite are you installing?  What operating system are you using?  Do you receive this error message prior to being able to initiate the install process?
    Jul 16, 2012 9:44 AM   in reply to KO333
    If you double click on ProductionPremium_CS6_LS7.exe it will extract the .7Z file for you.  You can then access the setup application in the extracted folder.
