Black Becomes Gray Only When Image Placed
Jul 14, 2012 4:48 PM
I am new at InDesign (CS5) and having a problem.
I have the output set to rich black etc and have a file with pages that have an RGB 0,0,0 black background.  When I put text on a page it seems to export to pdf with a jet black background.  However if I place a .jpg image on the page and then reexport the exact same page the background will turn to dark gray not black.  Remove the image and it exports as black again.  The picture can be quite small but yet the entire page packground goes dark gray.  What gives?  I can't figure it out.  Any help appreciated.
TRhanks.
Howard
    Jul 14, 2012 6:53 PM   in reply to hpg1
    What is your Transparency Blend Mode (found under the Edit menu)—RGB or CMYK? Do you have overprint preview turned on (under the View menu)?
    Choose Window > Output > Flattener Preview? Turn on Highlight: Transparent Objects. Do you see anything in pink (transparent)?
    Jul 14, 2012 7:59 PM   in reply to hpg1
    Well, I'm trying to work it all out from your description.
    Another question: What PDF export setting did you use when you created the PDF file? I'd guess you picked PDF/X-1a or PDF/X-3, right?
    If so (or if you used a PDF output with Acrobat compatibility set to Acrobat 4), your pages which contained transparency were flattened. Flattening will force all objects to the transparency blending space chosen causing color shifts.
    Try choosing a PDF preset setting which uses Acrobat 5 compatibility (High Quality Print, Press Quality, etc.) Flattening will not be necessary.
  • Rob Day
    Oct 16, 2007
    Jul 15, 2012 5:25 AM   in reply to hpg1
    Why does that small transparent object make the whole page background lighter than it should be?
    Is your PDF destined for print or screen? If it's for screen (you want to keep all of the objects as RGB) export to  PDF/X-4, which prevents flattening and color conversions.
    If it's for print set your Transparency Blend Space to CMYK and make the black background a CMYK rich black—something like 70|60|60|100. Also make sure Black Point Compensation is checked in Color Settings:
  • Rob Day
    Oct 16, 2007
    Jul 15, 2012 10:13 AM   in reply to hpg1
    Thanks....when I export to PDF/X-4 all the pages have a slightly less than black background......at least they are consistent, but not the proper deep black.
    So the black shifts in Acrobat not ID? Are you viewing with Acrobat's Output Preview open? If so what's the Simulation profile set to?
  • Rob Day
    Oct 16, 2007
    Jul 15, 2012 3:48 PM   in reply to hpg1
    Not sure what you meabn by Acrobats Output Preview
    AcrobatPro provides a number of soft proofing options that will show you how a document will print or how RGB objects will get converted into CMYK.
    If your  ID and PS black objects are really 0|0|0 RGB, your Transparency Blend Space is really RGB, and you don't have Overprint, Separation Preview, or Proof Colors turned on then 0|0|0 RGB will always display as absolute black in InDesign. Here's an ID black and a PS black with transparency:
    If I turn on Proof Colors there are setups which would preview 0|0|0 RGB as something less than absolute black—something like this:
    AcrobatPro also has soft proofing tools which could effect the preview of 0|0|0:
    But in Acrobat Reader there's no soft proofing so I think 0|0|0 will always display as absolute black, so in your case you should use Reader because that's how the document will likely display online:
  • Rob Day
    Oct 16, 2007
    Jul 15, 2012 7:06 PM   in reply to hpg1
    Can you post a sample page along with the image? I can't replicate your problem RGB black with or without transparency exports unchanged for me.
  • Rob Day
    Oct 16, 2007
    Jul 16, 2012 4:09 PM   in reply to hpg1
    The ID file would be more useful.
    Copy a problem page into a new doc, package it along with the image(s)—don't need to include fonts—and email it to the address in my profile.
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 3:45 AM   in reply to hpg1
    I can't see any problems with either the ID or PDF file. Acrobat shows the black as 0|0|0 with any RGB profile loaded.
    Here's your PDF as a page on my server and it looks ok viewed in a browser also.
    http://www.zenodesign.com/ftp/problem.pdf
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 5:38 AM   in reply to hpg1
    One thing that is changing is the type weight which creates an illusion of the black changing. The flattener preset in your ID doc was set to Low, which is affecting the display of the transparent page 1 in Acrobat and some browser PDF plugins.
    Here's your doc saved as PDFX-4 with a high res flattener. In this case the text weight looks the same on both pages in both Acrobat and a browser:
    http://www.zenodesign.com/forum/problemx4hr.pdf
    Jul 17, 2012 8:07 AM   in reply to Rob Day
    Hmm . . . Rivers of Steel, Carrie Furnace.
    hpg1,
    By any chance, are you Howard Grill?
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 12:37 PM   in reply to hpg1
    Looking at this more closely there is a shift in black when you export your doc flattened, which includes an interactive PDF.
    If you export a PDF/X-4 the transparency is not flattened and the black stays at 0|0|0. Your PDF is not X-4, I assume because you need to export an interactive PDF.
    It looks like a bug to me—I didn't bother screen capturing and measuring the black at first because Acrobat shows it as 0|0|0, but it is displaying as 8|9|8. It seems like a bug because it only appears to happen when the  transparency on the page is from a placed image.
    There does seem to be a work around—try including a completely transparent InDesign object somewhere on the page—that worked for me.
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 1:22 PM   in reply to hpg1
    made a 10 pixel by 10 pixel transparent image with nothing in it but the transparent background layer and placed it in a frame on the page and exported.
    No not an image. Draw out a rectangle on the page (can be any size), fill it with a color and set the rectangle's transparency (not color percentage) to 0. It has to be an InDesign native object not another image.
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 1:54 PM   in reply to hpg1
    Here's a screen capture of an interactive PDF where the ID page included a red filled rectangle set to 20%. You can see the RGB readout of the capture in PS is 0|0|0
    Here's an interactive PDF of the page without any native transparent objects and your one transparent PSD—the readout is 8|9|8:
    Message was edited by: Rob Day
  • Rob Day
    Oct 16, 2007
    Jul 17, 2012 4:34 PM   in reply to hpg1
    I did my testing in CS6 so no it has not been fixed—it probably has never been reported, it's hard to see.
    I think it is a bug, I can't think of any reason why 0|0|0 black would convert to something other than 0|0|0 when making RGB-to-RGB conversions, so its not likely an expected color management thing.
    I realized it was a place image problem when I tried eliminating your .psd from the mix and testing my own transparency.
    Jul 17, 2012 5:01 PM   in reply to hpg1
    Howard,
    Bo LeBeau is just a login name nothing more.
    Like yourself  I like taking photographs at the Carrie Furnace.
    I may have commented on your blog in the past.
    take care,
    Bo
