If I'm moving an image across the screen, the final keyframe will not snap to the end of the clip (even though it does snap to the edge of the window). This is with the keyframe timeline zoomed-out. Once I snap the keyframe to the end, I have to manually zoom in on the keyframes, find the last keyframe which should be at the end of the clip but it's not, and then drag it to the absolute end of the clip.
Anyone else having this problem? I have to do this every single time!
Screenshot 1: Keyframe snapped to end of clip, timeline zoomed out.
Screenshot 2: Timeline zoomed in, Why isn't the keyframe at the end??
The final keyframe can not be right at the very end. ie the right hand edge of the last frame
Key frames are time based and so the very end is actually ... "time over"
eg head of first frame in a 30 SECOND (PAL) timeline is 00:00
The last frame in a 30 second program (PAL) is 29:24
AT 30:00 there is no image because "time is over" (complete)
Marks and keyframes relate to the "left hand edge of the frame" ie the beginning of the event in time
But the keyframe snapped to the end of the clip in CS5.5. This never used to be a problem. Now in CS6, if I don't manually drag the keyframe to the very end, my moving images stop moving just before the end of the clip - because the clip is longer than the final keyframe.
Is anyone else having this problem? This is a major issue for those that deal with a lot of images / slideshows.
The first is 00;09;20;00 and the second is 00;09;23;00
That's because I've zoomed in. The timeline adjusts automatically when I zoom in.
Not sure what you mean by "snap" to the end of the clip or how you are setting the keyframe.
I drag the keyframe to the right edge of the clip using the mouse. The keyframe snaps to the edge if you drag it to the start or end of the clip.
If the CTI is at the end of the Clip...that where the keyframe is placed. Precisely.
The method I'm using is with the mouse and dragging the keyframe to the end. As I mentioned, this has never been a problem in previous CS versions.
I recorded it. You can see me add two keyframes: one at the beginning of a 15 second clip, one at the end. However, when I zoom in, you can clearly see the keyframe is located 10 frames before the actual end of the clip.
I can upload the original high-res video if the YouTube video isn't clear enough. I wonder if this is some kind of window-metrics problem, ie, the Effects Controls window isn't properly aligned to the absolute end of the clip.
O.K
I set my CTI before I set the keyframe. ( If I need to move the keyframe subsequently, I drag it after I set it but always to another CTI position so that I can monitor it)
If I want a keyframe at either end of the clip I use the keyboard shortcut eg PG-dn /up (CS5) or Up/Dn arrow keys (CS6).
That snaps the key frame to the end of the clip (edit point).
Reason I do this is that I dont usually have the Effects Window expanded enough to see the entire key frame setting pathway ( as per your your effects window as shown)
I've experienced something just like this too. If I have a clip selected, and am moving the CTI in the Effect Control window, I can move the CTI past the edge of the window. If I put the CTI at the exact edge of the effect control window, the CTI is roughly 18 frames ahead of the end of the clip in the timeline. Like Prizm said, it's like the effects window isn't aligned to the end of the clip. I can scrub to the end of the clip in the effect window, but then I can't see the CTI anymore, it's hidden behind the edge of the window.
Good find, this looks like it's related to the same issue. I've sent in a bug report for these problems. Hope they'll be able to fix it soon.
I just came across the same problem. I have been using PPRO since 1.0 (and before it was PPRO) and this is the first time I have seen this behavior....really annoying. The reason why I don't set keyframes at the end of clips is because if you use arrow up to go to the end of the clip you see the first frame of the next clip...little bit tough to set a keyframe when I can't see what it is effecting. I usually set a keyframe in the middle of the clip using the effects control panel so I can see the effect and drag it to the end, but not moving to the absolute end is killing me...It's a few frames off. As mentioned, if you are panning an image it stops moving before the duration of the image is over.
For solidarity I, too, have noticed a similar issue.
I cannot remember the exact circumstances, but I was in a hurry and dismissed it as human error. Zooming into a misplaced keyframe in the effect window was not possible. Its behaviour seemed very different from that of CS5.5.
I will investigate further now I know it's not just moi!
I have had the same issues moving the CTI in the Effect Control window, I can move the CTI past the right edge of the window. Arrow up sets the CTI correclty at the beging of the clip. Arrow down takes the CTI a few frames ahead of the end of the clip in the timeline. I thought is was human error, but now will report as a bug.
I shouldn't have to mess around with going to the end of the clip then back one frame due to a bug. I should be able to just drag the keyframe to the end of the clip in the effects control panel (Like I have in every other version of PPRO. Makes keyframing in the effects control panel not that great. You can move the keyframes on the timeline, but you can only see one property at a time.)
Also, if there is a transition on the end of the clip you are applying keyframes to it makes it tough to see the effect of the keyframe on the clip. I like my keyframes to be at the end of the transition and not stop part way through.
There are a lot of workarounds to cope with it, but the fact is that the effects control panel does not display clips the way it should. The heart of the problem is that the effects control panel does not display the entire tail end of a clip. Part of the tail is obstructed by the UI. The number of frames obscured by the UI is proportional to the length of the clip (longer clips have more frames hidden).
I am out of town today, but tonight I plan on creating a fast video capture of the problem to help people see what exactly I am talking about...hoping Adobe will have a fix for it soon...
AFAIK and recall..its always been this way. One backs up one frame from the end of the clip to set the last achievable keyframe.
(The end of a clip is "the end of the clip". ie. time is over and the clip has ended. There is no place in time to insert key frame data once the clip is over.)
I am not seeing any difference in CS6 from CS5.5 in this regard.
I do not have any obscuring of the last frame. The clip is displayed end to end. One can not see past the end, The slide bar is max limited to the extent of the clip.
Wondering if you have customised your Workspace (UI)?
I think I see a couple of related problems. I upgraded from CS3 to CS6 so I don't have a historical reference for this. Maybe some of the other old timers can pitch in a few comments.
First of all, I can't get the keyframe in the effects window to snap to the video frames. I have it set to do that, but it doesn't. I took away the ability to snap to anything else. Didn't help.
To recreate this problem, zoom all the way in to the effects window and then create and move a keyframe around. Nice and smooth, isn't it. But wait. Should it be smooth? No. It should stop at a frame. Not in the middle, or 3/4 of the way through. It should stop at the same places the CTI stops when you step through the video one frame at a time. Right? Yes!
I also see that the only way to get a keyframe to the end by using a mouse is to zoom all of the way in and then move it to the right. It appears that the vertical scroll bar is covering some of the effects window. Like they used an "inner stroke" instead of an "outer stroke". I think I got those terms right. So you can't actually see the end of the effects window, therefore you can't put anything there. It seems that the closest I can get while zoomed all the way out is about two and a half frames. Yes. I said it. HALF! Yikes!
So, as much as I don't like the idea of using end and arrow back one frame when I have a perfectly good mouse in my right hand, it appears that the only way to do this quickly is to give in to the keyboard fanatics. The mouse haters. You know the ones. ![]()
Or, move the keyframe and zoom all of the way in - then move it more.
Looks like a bug to me. I am curious if Adobe would prefer a bug report or a feature request.
-- Steven
shooternz,
Of course you are correct. However, there are occasions when you want to set a keyframe in the middle of the clip and then drag it to the end. Why? Well, what if the video has a dissolve to black at the end. You can't see it. So how do you adjust the position, or the size, etc. So you create the keyframe before the fade to black, and then drag it to the end. But wait. Where the heck is the end? I have to put it almost at the end, then zoom all of the way in and move it the last little bit. On my system, it is about 2 and a half frames.
So, pressing end, or down arrow. Either way, I have a mouse in my hand at that moment because I was messing with a rubberband. Why do I have to let go and use the keyboard?
I am not saying this is a critical issue for me personally, but it is a bug and should be fixed.
I am in San Jose quite often. I now live just up the road in Oakland. I would be happy to stop by and show the Adobe folks what I mean. ![]()
Its interesting how we all work differently
eg
Generally I still work the same as I did when editing film on a bench / flat bed. I make the edit and then do the transitions and heavy fx (cc/grade). If I have dropped in a transition and run into the situation you mention...I simply drop it out then restore it.
I also have been known to set a KF at a notional point in the clip and shift it around until it works for me. Including the end.
BTW - If I drag a keyframe in FX Control Panel hard right to the limit and then back space one frame (Left Arrow). That is also the last keyframeable frame in the clip
It is interesting, isn't it?
I may be old, but I didn't get my first video camera until I was in my late 40's. So I am still a beginner.
If I could drag the keyframe all the way to the hard right, and have it be at the beginning of the last frame, I would be a happy puppy. But two and a half frames is just plain annoying.
If I could set the CTI at the beginning of the last frame and use my mouse to drag the keyframe and snap to that point, it would be fine.
But when I drag the keyframe and it doesn't snap to a frame. Any frame. Or the CTI. Well, enough said.
It is strange and I have tested and tested this on my CS6.
If I mouse drag the CTI or a keyframe in the FX Control Window...hard right ...the indicator is definitely on the end limit of the clip and one frame back shows the last frame of the clip.
At the limit ..I can only see 1/2 of the Orange Knob on top of the CTI or half the keyframe symbol. Just enough to grab either with the mouse. Of course if I keyboard it back with the arrow keys..it is easy to get hold of it.
I just can not replicate the two and a half frames issue.
Here is a short video I just created illustrating the problem. I hope it is clear. I appreciate all the help from fellow users. I'm just glad that I don't animate pictures as much as I used to...please let me know if anything in the video is unclear. I would recommend watching it on YouTube in HD http://www.youtube.com/watch?v=k4T1WZhj588&feature=youtu.be
I can see that clearly. Well presented.
But ..I can not get my system to do exactly that "short of end" issue.ie a few frames difference between the end of the clip in FX an Timeline.
The issue I do get is that indicators and keyframes gets stuck under or hidden by the vertical scroll bar in the FX Control Window.
The issues are related somehow and I agree a fix is needed
Instead of changing the size of the panel, just zoom all the way in. From there you can get to the end. As long as you are close to the end so you can see the keyframe when you zoom all the way in, you should be good to go.
This is rather like unpinning from the clip, but you don't have to be quite as careful. Just grab it, slam it to the right, and move on.
I was going to provide video, but I just looked at the clock. Time to get some sleep.
I am not so sure that it is still there.
I just imported a still into a project, put it on the timeline, and up in the Effects Control panel, I was able to drag the CTI all the way to the right. Since this was the only thing on the timeline, when I drag to the right, the Program Monitor goes black. As expected when at the end of the timeline.
Sometimes the CTI looks like it is just before the last frame, but when I release the mouse button it moves one to the right and the Program Monitor goes black.
I tried again with a video clip. It works the same way.
By George, I think they've got it.
I tried what you did, and you are correct, but I think we've always been able to do that. The problem we're having is that when we drag the CTI in the effects control panel all the way to the right, it actually disappears behind the vertical scroll bar of the effects control panel. I'm guessing that's what happened when you did it. And because that works that way, if you were to create a keyframe and drag it to the "end" of the clip in the effects control panel, the keyframe won't move behind the vertical scroll bar, so it's always a few frames short of the end of the clip. So you have that extra step of zooming all the way in in the effects control panel and dragging the keyframe to the last frame of the clip (assuming that's where you want it).
I'm still having the problem after the update, so I really don't think they've fixed it. I'd probably agree with Jim Simon on this one. It's quite a small issue compared to fixing random crashes and footage becoming unlinked.
I am experiencing the same problem, i.e., the key frame window CTI and key indicators are hidden behind the right vertical scroll bar for the last few frames of the clip. The workaround that I found is to move the left re-sizing edge of the window (even slightly will do) and the window "wakes up" and and will show the last frame in the clip. That being said, the CTI and the key indicator are only "peeking" out past the edge, making them tricky to click on, even with a 24" monitor.
