iLOK and CS4 problems
Jul 14, 2012 3:09 AM
Hello.
I know this is an older version, but I am at a complete loss as to understand this.
I need to run up this version in particular, and on launch I get a message telling me that Auto Tune 7 cannot be loaded as it "requires a valid license on my iLOK" to run.
However, this is present & correct as the plugin loads properly in all other VST Plugin hosts.
Why isthis happening - anfd how can I corect the problem please?
    Jul 14, 2012 9:38 AM   in reply to Neil Wilkes
    Neil,
    PrPro can have some issues with certain VST's. Some can load fine, but not work in PrPro. Some, however, will fail upon launch, not load, and will be written to a "blacklist," in about PrPro CS 3 and later. After all such VST's have been added to the blacklist," PrPro no longer tries to load them, and launch proceeds smoothly.
    However, that does not seem to be the issue with iLOK, as you are not getting the hang of PrPro during launch, and it seems that iLOK is getting to the point of loading, except for that license data. This is just a thought, as I do not have, or know iLOK, but perhaps some aspect of its loading by PrPro is failing to find that license info (ini, or similar file?), so its loading is not completing. Do you know where that licensing info is being stored? In the loading process in PrPro, are you presented with an active dialog screen, that might allow you to type in that licensing info? It might take a contact with iLOK's T/S group, to find a way for PrPro to get past that point, and act as a proper host app.
    Wish that I had more, but can only rely on some general experience with PrPro hosting of VST's.
    Good luck,
    Hunt
    Jul 14, 2012 10:11 AM   in reply to Neil Wilkes
    Well...one method of correcting the original problem (out of tune notes) is to upgrade to CS6.  Audition now includes this capability by default.
    http://tv.adobe.com/watch/learn-audition-cs6/pitch-correction/?go=1334 9
    Jul 15, 2012 9:32 AM   in reply to Neil Wilkes
    If you can't get it working, you may have to either upgrade the 32 bit to 64, or do the pitch correction on the current CS6 computer and move the file back for the rest of the work.
