I would like to add lots of subtitles to my content inside PrE. If you think of the "stock ticker" on CNN that should give you a good idea of the desired output. Getting started was easy enough- drag one of the "lower 3rd" titler presets with a nice background onto an empty video track, change the text, add some effects and transitions.
Now I wanted to duplicate this overlay for the next scene same appearance but different text. Copy & paste of the clip maintains the appearance but seems to just insert a new instance of the title and not a copy. In other words when I change the text in one of the clips it is changed in both.
Then I tried the Duplicate command in the Project window. That makes a duplicate of the title but it won't preserve effects/duration/transitions of the clip.
Any recommendations ?
You will want to use Duplicate for your Lower-Third Title, as many times, as is needed, and alter the Text on each, to suit.
Unless you use Duplicate for the Title, what you have are Instances of the "master" Title, and if you change one Instance, it will be global for all other Instances. That can confuse users, if they do not expect it.
Good luck,
Hunt
Yeah that was going to be my follow-up question: would it be possible to just have one instance of the title (with background & effects) and then have the text crawl in front of that.
The project is 720p24, so width = 1280. What's the width restriction? And how would I get started with adding scrolling text ?
While one could create the Title completely in Titler, when one gets much beyond the width, or height of the Frame, editing becomes a bit of a task. Photoshop, or Photoshop Elements would be better programs, in my estimation.
Here are the steps that I would use:
If your Duration needs to be longer, then think about breaking those PSD Titles into logical segments, creating a new PSD for each one.
I have not done a really long Crawl, but have done many very long Rolls where the height of the Title in PS is extremely tall. The only difference then is that I adjust the vertical, rather than the horizontal Motion>Position, and Keyframe on that.
Good luck,
Hunt
[Edit] As you are creating animation from Still Images, you will see a red line above the Clips and Titles. After you do your Keyframes, you WILL want to Render that area of the Timeline, for smoothest Playback.
Message was edited by: Bill Hunt - Added [Edit]
Thank you very much Bill.
I will probably do that approach with a few modifications. Since it doesn't matter if the text crawls or rolls I'll switch to rolling which should make editing easier in Photoshop. All that's required then is applying a mask so that only one line of text is visible at any given time. Let's hope the masking tools in PrE support this.
I just did a test, as I had never done such a long Duration Crawl, and in PrE, I was able to Import a 13000 x 130 pixel PSD. Now, in the test Image, I used 24pt Type, and when I got it into PrE, I realized that 30 - 36pt Type was better, so I cheated and just used Motion>Scale>Height (with Constrain Proportions unchecked). I did not do the math, but think that one could easily get 14000+ pixels on the width, if they Crop the height to just above the Text.
As for the Roll, the one limitation that you will run into is that if the Text goes for much of your width (1280), then you will have less height to work with. Since you will want you Text inside the Title Safe Area, you can Crop the width some, to just before and just after each line of Text, but you'll probably end up with about 6000 pixels in height.
For my long Rolls, I am usually going Widescreen SD, so am still dealing with 720 pixels width, but 5000 - 6000 pixels gets me a lot of material on screen.
To Mask your other lines of Text, just place a Mask (can be made in PrE's Titler, or PS) on the top Video Track, and apply the Track Matte Key to the Text PSD, linking to that Mask.
Good luck,
Hunt
As your request was about the 10th similar one, I did an ARTICLE on Rolling, or Crawling long Titles.
Maybe that will be helpful.
Good luck,
Hunt
Maybe the description was not clear. I have created a PSD similar to your steps 1-6. In step 7 when I import the PSD into PrE and drop it into the timeline that PSD gets scaled down to ca. 120x720 pixels. Apparently PrE tries to shrink down the imported image so that it fits inside the frame. How can that be prevented ?
Good catch.
I had not even thought about that, as I never use it. I Scale everything in PS, or if in PrE, it is to animate something.
Some users employ Scale to Default Frame Size, rather than doing that work in PS, or similar, and there are some drawbacks to doing so.
Thank you for pointing that out, and I am now off to add that to my article.
Good luck and happy editing,
Hunt
Hello Bill;
I have tried following your suggestions on rolling subtitles using a track matte key to limit what portion of the scrolling title is visible to a single line at a time, but I've run into a frustrating problem. I'm doing this in Premiere Pro CS5, and I can get it to work just right in a "empty" portion of the timeline where I set up the title roll, the matte, the background video, and even an intermediary grayish box to give the white subtitles a background to make them more visible. In this practice zone I have these 4 things all placed in video tracks 1 - 4.
However, for the one-hour documentary this is needed for I have about 8 video tracks and when I place the exact same elements in video tracks 1 and then 6 - 8 it doesn't work at all and creates a number of very odd flashes. This is in the same timeline where it works fine when placed in tracks 1 - 4. I have been careful to verify that the track matte key is pointed at the appropriate track number.
Do you know why this would be?
Thanks, Jim Greeson
Jim,
I would post to the Premiere Pro CS 5 - 5.5 - 6 Forum, with the same details, and perhaps a screen-cap of your Timeline, showing what you have and where. There are significant differences between the Timelines in PrE and PrPro, and there are differences in how many things work between the two programs.
Good luck, and I'll see you there.
Hunt
