Im trying to understand the exact sequence of events that occurs as a video is rendered in order to more precisely tune my computer for video editing. Ihave CS6 Production Premium ( or what ever its called this release.
I have 3 hard drive arrays on 2 separate Adaptec RAID and a Nvidia gtx680 in a dual Xeon Hex core 2.5ghz machine w/48gb of 1600.
I want to set up the most efficient I/O for Adobe but still struggle to understand the way the software processes video between the various files it creates.
You have the RAW video files ( 1volume) you have the Rendered Files ( 1 Volume for storing the rendered video) then there is things like the media cache, and the data base. What kind of resources do these need, how do they relate to I/O, and How much bandwidth do they use... Also getting in to After Effects, whats the difference between the media cache and disk cache?
Any help on this would be great, again Im looking for how all this ties together as a process so I can better tune my computers RAID volumes.
thank you in advance.
I'm not sure if the CS6 benchmark is fully operational, so also go to the CS5 link
CS6 Benchmark http://ppbm6.com/
CS5 Benchmark http://ppbm5.com/
The ideal is to minimize reading and writing to the same drive at the same time. So here's a good real world setup.
C: System
D: Media
E: Projects
F: Scratch/Cache
G: Exports
H: Images (from Encore as Masters)
As you lose drives, you move the missing components up, so without H, you put Images on G. Without G, you put Images and Exports on F. Without F, you put Images, Exports and Scratch on E.
You don't want to go any less than E:
OK so if I understand you then, the Images, Exports(what ever those would be...Same as rendered sequences?) and Scratch/Cache use the least amount of I/O and it is best to have them together than on other disks that may have Higher I/O. Currently I have a 8 drive volume as my Source media drive where i store all my raw footage, and a 4 drive volume where I send all the rendered media to when I render the edited sequences, I also currently keep the cache and scratch on the C drive or in their default location( where the project files is) which is usually the same drive as the Raw footage.
So let me ask you this...
you think if were to break up that 8 drive volume and make it 2 4 drive volumes and put the project files and scratch/cache on one and the rendered video writing tot he other it would make my system render more quickly?
thanks again for the advice.
See: Adobe Forums: Generic Guideline for Disk Setup
and Adobe Forums: To RAID or not to RAID, that is the...
and Adobe Forums: Raid Performance and Rebuild Issues
Jim has not yet seen the light on raid arrays, so he has a natural tendency to advise to only use single disks.
Any one of the drives I mentioned can be a RAID, Harm. I've no quarrel with that. In fact with tapeless media, I do often recommend the Media drive be RAID 3. None of this contradicts the spread as indicated.
With a total of 13 drives, here's what I might recommend.
C: System
D: Media (x4, RAID 3 or 5)
E: Projects (x2, RAID 1)
F: Scratch/Cache (x2, RAID 0)
G: Exports (x2, RAID 0)
H: Images (from Encore as Masters) (x2, RAID 1)
THAT config would be screaming fast! And would offer a good measure of security for the important stuff, the media and project files.
Welllllll actually I have 16 drives... all raid 5 1) OS 2)Renders 3)raw footage/projects 4)storage...
all have 4 drives ea.
would you care to cretail your last drive asignment to fit my box please. Im opent to rebuilding raid arrays. I should also state that the OS is on a 4 drive SSD array
thanks again Jim, I appreciate your help!
C: OS - 250 gb ( raid card 0)
D: (renders) 950 gb _ thisis the 8 drive raid 5 I could break up in to 2 420 gb volumes. (raid card 1)
E: Captures and Raw Footage - 830gb (Raid card 0)
J; External RAID 5 ESATA Enclosure - 3.2 TB(7200rpm)
thanks, again I wouldnt mind breaking up the D drive in to two different volumes.
I just want the most effifient stream like high speed low drag data shover i can make!
OK, here's what I'd do.
C: System (80GB SSD x 2, RAID 1)
D: Media (1TB x 4, RAID 3 or 5)
E: Projects (300GB x 2, RAID 1)
F: Scratch/Cache (150GB x 4, RAID 0)
G: Global Cache (for AE) (80GB SSD x 2, RAID 0)
H: Exports (143GB x 4, RAID 0)
H: Images (300GB x 2, RAID 1)
This gives you data protection on the critical drives - System, Projects, Media and Images (Masters) - and speed on all of them.
On a side note, what the hell case do you have that can hold 20 hard drives!?
HAHAHAHAA Laughing at your last comment. Thanks fo rhtat answer...
The Hard drives are not 3.5 FF, they are 2.5. I use a product from thermaltake. Look upThermalTake MAX 1542 and 1546. Or have alook at the short video i made on it.(warning, bad camera shake ) I also have a video on the build when I made this computer. Also the other 4 hard drives are in an eclosure that has its own raid controller and is attached via E-Sata/
Enclosre: http://www.youtube.com/watch?v=ZI5gxsV-Whw
Machine Build-Dual Hexcore Xeon 2011 with 48GB RAM: http://www.youtube.com/watch?v=X_2a7oEgDHQ
thanks again for all your help sir!
Just for your info, a simple Lian Li PC-A77 easily holds 17 3.5" disks and with different drive bays can hold 19 hard disks plus 2 BR burners.
The case I'm using for my new build can hold 31 3.5" HDD's, 4 SSD's and 2 BR burners and a multicard reader. See: Adobe Forums: Planning / building a new system. Part 1
Pictures are included to see what it looks like. This is without modding, but if you want you can easily add another 8 disks for 39 3.5" plus 4 SSD's plus 2 BR burners plus a multicard reader. Then you can add a pedestal for another 16 or more disks. It will not achieve the space of an Aberdeen Petarack, but for most this will suffice.
