How to convert a VCD to DVD
Aug 9, 2012 9:01 AM
Tags: #premiere_elements_10
  Latest reply: VDOSurfer, Jul 18, 2012 5:09 AM
Replies 1 2 Previous Next
    Jul 15, 2012 4:18 PM   in reply to flyinjewel
    IF it is one of the options, and you want to edit in Premiere Elements, you want to convert to DV AVI type 2 with 16bit 48khz sound
    Jul 15, 2012 8:17 PM   in reply to flyinjewel
    Go to Google and enter
    convert vcd avi
    Jul 15, 2012 11:23 PM   in reply to Bill Hunt
    Bill Hunt wrote:
    Robert,
    Thank you for that info. Is that directly from PS CS6, or from Bridge CS6?
    By chance, do you happen to know if, when one creates a SlideShow in Photoshop Elements, that SlideShow is created as a DAT file?
    Appreciated,
    Hunt
    Bill, That is directly from PS CS6.
    When you burn a slideshow project to a VCD from the Elements Organizer, two -- among several -- directories are created on the CD with files that end with .DAT. The one file in the MPEGAV folder named AVSEQ01.DAT, on this one disc I have made, can be dragged to the timeline in some editors, such as Sony Vegas 10. The video is very low resolution, half of standard definition.
    I can use Movavi Video Converter to convert the AVSEQ01.DAT file to something else.
    Jul 16, 2012 5:33 AM   in reply to flyinjewel
    QuickMedia website shows compatibility with W7 32 & 64 bit. The other shows XP and likely works on W7 - if it doesn't, uninstall it.
    Cheers,
    Neale
    Insanity is hereditary, you get it from your children
    Jul 16, 2012 5:35 AM   in reply to Robert J. Johnston
    I think VCD is MPEG1 which probably explains that.
    Cheers,
    Neale
    Jul 16, 2012 6:43 AM   in reply to nealeh
    I agree, Neale. A VCD is pretty primitive technology -- roughly the equivalent of an old VHS recording, with about 1/4 the resolution of a DVD.
    Jul 16, 2012 11:45 AM   in reply to flyinjewel
    Though you may have used a black DVD disc, it appears that you burned a VCD disc, onto it. The files and folder structure differ between VCD and DVD.
    Good luck,
    Hunt
    Jul 16, 2012 2:49 PM   in reply to flyinjewel
    Bernice,
    Back on the old computer, the one in the closet, do you still have PSE 6? Do you happen to have that old PSE Project on that computer? If you do, you will be better off just outputting the Project again.
    Conversion programs are great, when going from file A to file B. However, if file A was compressed, or otherwise output, in a lossey format, no conversion program can improve things, when going to file B. Once data is lost, it is gone forever.
    Hope that you DO have that SlideShow on that older computer, and can just output again, with the proper settings.
    Good luck, and again, fingers are X'ed in Arizona.
    Hunt
    Jul 17, 2012 12:43 PM   in reply to flyinjewel
    I think what Hunt said was to power up the old computer and re-do the old project there, with all the original files... and output again to a new DVD, this time being sure to check the option to create a DVD, and not a VCD
    That will not involve your new computer at all... Then, do NEW projects on your new computer
    Jul 18, 2012 5:09 AM   in reply to flyinjewel
    Rename the .dat file to .mpg and then try to import it. It should work. I think PrE looks for the extension rather than the actual video content.
1 2 Previous Next
Actions
