BChilcher
Video captured with ground loop hum (analog interference)
Jul 14, 2012 1:37 PM
Tags: #bar #loop #composite #progressive #interlaced #ground #bone #interference #roll #hum #analog #herringbone #herring
A client brought me this clip on showsite last week. Before I had this video imported in my system, I only saw it in a 5-inch capture window and thought it was an interlacing issue. Turns out it is actually analog interference, caused by the composite feed from the MOTU HDX-SDI. The feed was sent out over a VGA-to-5-wire fanout cable on GREEN and must have picked up some interference along the way. When captured, it was assumed that was just the preview and that the video lookeed fine...
I am wondering if there is any way to remove a diagonal (herringbone) ground-loop hum from video. There seems to be a pattern to it, as it slowly rools up, then down a bit then back up and off the screen - only to start all over again... I will attach some a video of what it looks like.
https://www.dropbox.com/s/nesri9s7ngg5mq3/BChil%20Interference%20Sampl e%20-%20saved%20as%20DV%20codec.avi
This was recorded at 720x486, 29.97i in Apple Pro Res initially, but this uploaded clip is a 720x480,29.97i DV codec file. Should I de-interlace it first, or try to do something with it interlaced? Seems it would be easier to deal with frames than fieldsx2 when trying to isolate this interference, but not sure... Any help would be greatly appreciated!
-BC
Here is a still (with logo blacked out)
    Jul 14, 2012 2:53 PM   in reply to BChilcher
    This is not the kind of thing you can fix in post.  You need to fix it on site before you record it.
    Jul 14, 2012 7:34 PM   in reply to Jim Simon
    sure you can.  this can be done with an FFT plug-in.
    Heres an example of a Photoshop plug-in doing a similar job:
    http://video.google.com/videoplay?docid=2621356841303406132
    Jul 15, 2012 1:40 PM   in reply to Charles VW
    You think that can be done over multiple video frames?
    Jul 15, 2012 7:33 PM   in reply to shooternz
    Probably not with that particular Photoshop plug-in's workflow, but I know they're out there in the video world.  My point is to show that periodicity is a solvable problem.
    Jul 16, 2012 4:23 PM   in reply to BChilcher
    Though I use Neat Video fairly often, it's mainly for working with video noise, from underexposed footage (often ripped from old VHS material), and it's analysis is usually a good starting point, but as you point out, it does take some tweaking to get really good results. It's analyzer would be better, if the videographer had just shot a gray card, in the same lighting (oh, and also added some light to begin with, but that's another story).
    I find that just a hint of Sharpen, after Neat Image, improves things too. "Just a little dab'll do ya."
    Render and Export times DO go up.
    I have not looked at alternatives in too long, to be of use, but maybe others will have some favs.
    Good luck,
    Hunt
    Jul 16, 2012 7:19 PM   in reply to BChilcher
    Ugh, THAT is tough. Hope that you can get close, though.
    Good luck,
    Hunt
