doing a mixdown of a two tracks in multitrack
Jul 11, 2012 10:21 PM
I want to mixdown/render/bounce two mono bass clips (automated to include only the best segments of each) into a single mono clip that I can insert into Multitrack.  I want to do this because that's the way I've worked in the past, because it's tidy, and because it uses fewer instances of various plugins.  Okay, what's the best way to accomplish this?
I tried Multitrack>Mixdown Session To New File>Time Selection, but that produces a stereo mixdown.  Sure, I can then use Edit>Convert Sample type to change the stereo file to a mono file, but there must be a simpler, faster way.
    Jul 11, 2012 11:48 PM   in reply to therealdobro
    I was going to suggest "Multitrack->Bounce to New Track->Selected Clips Only" but that also bounces to a stereo track
    If you set your master out to a mono output it still bounces down to a stereo track with only one channel
    Looks like CS6+ needs a mono option
    Jul 15, 2012 2:01 AM   in reply to therealdobro
    Okay worked out how to do it - its a work around but it will do the trick
    Edit your sesx file in a text editor
    5th line would be something like this
    <session audioChannelType="stereo" bitDepth="32" duration="0" sampleRate="44100">
    Change the 'stereo' to 'mono' and save (or save as a copy)
    Now when you select your clips and 'bounce to new track -> selected clips' they will bounce to a mono track
    Jul 16, 2012 12:12 AM   in reply to therealdobro
    Correct - the sesx file for the session you are going to be working on
    I don't think there is a system setting for 'mono' - when you create a new session or open a different one things will go back to 'normal'
    Best I can do I'm afraid.
    Jul 16, 2012 3:42 AM   in reply to SuiteSpot
    You can select Mono for your Master when you open a New Multitrack Session. Bounce Master Down to New track then happens in Mono.
