I'm having trouble deploying the new combined 32/64bit version of Flash published through the SCUP cab catalog and SCCM Software Updates deployment. On every one of my machines the update fails with the same error. I have a mixed environment of Win XP 32bit and Win 7 64 bit machines.
I've previously had no trouble at all deploing Flash (and other Adobe updates) updates using the SCUP catalog and SCCM. It is first with 11.3.300.257, where the msi contains binaries for both 32 and 64 bit, that i experiece issues.
The error i get in the WindowsUpdate.log is:
WUAHandler.log (SCCM related log) gives the error:
Installation job encountered some failures: Error = 0x80240022.
UpdatesHandler.log (SCCM related log) gives the error:
Update execution failed.
The Windows Application Event Log displays nothing in relation to the msi, so no usefull info there.
Anyone else out there with the same issues, or with some guidance?
Br,
David
I know that the response is really late. Did you solve this issue?
If not, could you please do the following:
- Right-click and see if the installer is blocked.
- Try installing Flash Player using the command that you use in SCCM and see if it installs.
Sunil
Have, I am having the exact same problem. But 90% of my machines are fine. It is the about 30 machines, about 10% of the total, which fail with this error message. I cant see anything wrong with these machines, or anything in common thats different from the machines that patch ok.
This has occurred with all Flash ActiveX updates for Internet Explorer since I began using SCUP with SCCM.
any other advice that could be of use? Thanks!
