carolyn francis
LR4 Print Adjustment Feature
Jul 16, 2012 8:49 AM
What slider(s) in the Develop Module of LR4 matches the new LR4 Print Adjustment for brightness?
    Jul 16, 2012 9:12 AM   in reply to carolyn francis
    None. It's a separate control on top of develop adjustments. It only
    affects the print.
    Sent from phone.
    Jul 16, 2012 9:13 AM   in reply to carolyn francis
    None of them...Brightness in the Print adjustment is a simple gamma adjustment (although the units don't relate to specific gamma changes). There is no adjustment in Develop that is the same. Exposure would be "similar" but would not share the same unit adjustments...so, you can't use anything in the Develop modual to predict wha rint adjustment setting to use–it's a trial and error process.
    Jul 16, 2012 1:03 PM   in reply to Jeff Schewe
    An important question is that if one has a properly calibrated monitor with the appropriate luminance setting and is using soft proofing, is this adjustment needed? In his Lightroom 4 book, Martin Evening suggests that it is usually not needed.
    Jul 16, 2012 1:18 PM   in reply to Bill_Janes
    It is true; it's not needed. The problem though is that some of the calibration software recommend a luminance setting (sometimes also called brightness, or intensity) that is too high.
    The correct luminance setting is between 100 and 120 cd/m2 (candles per square meter).
  • Andrew Rodney
    Apr 16, 2009
    Jul 16, 2012 2:07 PM   in reply to web-weaver
    Indeed it is true. And how well do you suppose the sliders work IF you also use the soft proofing that is so wonderful in LR?  Worse, if you use it, you insure that any time you print the same document in any other application, you’ll get another result. Fix the issue, the display to print matching and leave the sliders two those who need a crutch and don’t understand the proper use of color management.
    Jul 16, 2012 2:54 PM   in reply to Andrew Rodney
    Andrew Rodney,
    I think there must be some misunderstanding: I was not recommending using the sliders in the print module - I am not the OP.
  • Andrew Rodney
    Apr 16, 2009
    Jul 16, 2012 3:57 PM   in reply to web-weaver
    web-weaver wrote:
    Andrew Rodney,
    I was agreeing with you.
    Jul 16, 2012 4:08 PM   in reply to Andrew Rodney
    Oh, sorry, I didn't catch that.
