PUBS101
INDIVIDUAL TO BE ABLE TO SAVE DATA ON THE DOCUMENT, BUT ONLY FOR A CONTROLLED PERIOD OF TIME.
Jul 16, 2012 5:25 AM
Tags: #adobe #data #email #dynamic #livecycle #form #submit #pdf_fillable_forms #livecycle_designer
I'm trying to create a form, that will be sent out to individuals via email. They will fill out the form over a course of a few weeks and send back via email. My question is, is their a way to limit the time a form can be usable, i.e. enable it that after a few weeks or after it's been open a few times, that the user can no longer type in the form or print it?
Can this be done? or a variation of this?
Looking forward to replies!
    Jul 16, 2012 10:01 AM   in reply to PUBS101
    Here is a low-security approach: http://assure.ly/frjYW5.
    Hope that helps,
    Niall
    Jul 17, 2012 7:36 AM   in reply to PUBS101
    I can't check at the moment, but I suspect that I created a page in LC Designer and then set it's presence to hidden.
    If you explore the hierarchy, it should become apparent.
    Niall
    Jul 19, 2012 12:54 PM   in reply to PUBS101
    If you go to the hierarchy and select the security page. You can then drag this up the hierarchy so that it is above the first real page.
    You will need to change the pagination, so that all pages are set to Follow Previous and Continue Filling Parent.
    Lastly, set the security page presence to hidden (not invisible). Also the script should use hidden and not invisible. See an example here talking about the presence property: http://assure.ly/h7whb8.
    Hope that helps,
    Niall
