Hi. I am having problems opening several illustrator files, and pasting a vector from illustrator CS6 to fireworks CS6.
If I try to open an .ai file that I normally would open just fine in fireworks CS5.x I get an error that says:
Could not open the file.
An internal error occured
If i try to copy in Illustrator CS6, then paste to fireworks nothing happens.
This is occuring with multiple files, that are small in size, even selecting simple vectors and pasting is not working.
I tried creating a new file in Illustrator, pasting the shape from the other file, saving it, then working with that file in Fireworks, still does not work.
I tried rebooting.
12.0.0.236 , windows 7 ultimate x64, i7, ssd, etc..
Arthur
I tested with a few .ai files, and I was able to open them fine in FW CS6. I was also able to copy between the two apps.
I'm on Windows 7 64 as well.
Can you share one of the files where you are having the issue?
Also, when you're pasting, does it fail when you use Edit > Paste, or just keyboard shortcut?
Can you paste into some other app from Illustrator?
Hi Carey, thanks for the response.
Ok so interestingly I am home now, I was able to get this to work just fine on my laptop with the same os. I had cs5.5 from my subscription installed on both, then last night i uninstallted that on both, and installed all the apps from creative cloud.
When I try it here I dont have the larger fireworks png available to paste into but I rdp'd back ot my office and tried with a blank document importing a logo it failed, so I dont think it is with the document I am trying to import into as it doesnt work with a blank file at my office.
I am sharing a file that I am having a problem working with. http://dev.rofsky.com/debug/Grad.ai
It failes when i use edit paste, and keyboard shortcuts, as well as import from the file menu. It doesnt even pop up the window that asks you about import options.
I have no problem pasting the same item into photoshop.
This laptop that it works on is a dell e6420 with intel onboard graphics, the workstation has a evga gtx 460 . not sure if that would make much of a difference?
Both computers are good hardware, genuine os and software all around with all service packs and updates installed.
I tried working with the same file from a network drive and the desktop of the workstation.
Okay, here is what I've found. I created a doc in AI and FW, each with a single red box (created with each app). I can go from FW to AI, but not AI to FW.
Using the command menus or shortcut keys makes no difference. In FW, the 'Paste' mene item is available, but nothing happens whan it is clicked.
FWIW, I created the same sort of doc with Paint, and it copys/pastes fine between both applications.
Also, in AI, after clicking 'new document', and before the document options dialog opens, I get an error/confirmation dialog ehich says "The operation cannot complete because of an unknown error. [CANT]".
Upon clicking 'OK', it goes about it's business as if nothings wrong. Don't know if that's in any way related...
I've been able to open AI files, and File > Save As Photoshop in FW CS6 with no issue yet. Likewise, drag and drop as well as copy/paste are both working for me, AI - FW. I'm on a MacBookPro running Snow Leopard.
I have alerted the engineers to this thread. It would be helpful for them to know your OS and version (each of you) as well as what other apps - if any - are running when you experience these issues. The more details the better. And ideally, report the issue and all the details to the wishlist. Bugs or issues submitted via the wishlist are logged and read. This is a user to user forum, so it is not regularly monitored by Adobe staff.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Hi All:
Just a note regarding the wishform. Your detailed input on that form is importantant and I really appreicate you taking the time to help make Fireworks a better product. So thank you for filing these bugs.
Keep in mind that even though one person may have indicated they filed the bug, you should also file your own bug on the issue if you are experiencing problems. This reporting makes the engineers aware of how prevalent the issue is and helps to prioritize which bugs get addressed first. Yes, I know, in an ideal world, they'd ALL be marked as high priority, but that's seldom the case with anything. Squeeky wheel gets the grease, etc...
Also, filing the bug doesn't necessarily mean you will personally hear from the engineering team. This is a quote from the form itself:
>>We normally do not send personal replies to feature requests or bug reports. We do, however, read each and every message. We use the information to improve our products and services. Your comments, suggestions, and ideas for improvements are very important to us. We appreciate you taking the time to send us this information.<<
That said, I'm making an effort to bring these threads to the attention of the FW team, and if I hear anything myself, I'll be sure to let you know.
HTH
Still nothing on this problem?
I'm really struggling with this issue, I'm only days away from downgrading back to CS5!
Can Adobe at least just announce there is NO FIX, rather than no information at all, I mean... come on!
And yes I filled out the feedback/wishform/support form with all the info they need. I'm on Windows 7.
I've alerted the FW team about this thread again. I'm wondering if the issue lies on the Illustrator side, but I can't say for sure, either way.
FYI regarding the wishform. The wishform is a bug logging mechanism only; it doesn't mean anyone from Adobe will reach out to you directly. In fact, it states as much on the page.
Hi there,
I had the same issue as the others on this post. I found a solution:
1. The problem seems to be related with APPLE QUICKTIME installation. So if you have quicktime installed, just uninstall it and everything will works fine again: you can import your .ai files to fireworks.
2. This worked for me: I tried to reinstall quicktime (because I use After Effects) and everything are still working.
3. In case you don't use after effects try to download k-lite codec pack as an alternative to quicktime
Hopefully it helps someone!
