russian_box
Output file wrong length
Jun 10, 2012 1:51 PM
Tags: #cs5.5 #encoder #timeline #stopping_short
Hello!
I am having problems with exporting videos out of After Effects using 'Adobe Media Encoder'
Adobe Media Encoder CS5.5 v5.5.0.2012 (64-bit)
Adobe After Effects CS5.5 10.5.0.253 (64-bit)
Windows 7 Home Premium (64-bit)
I have 2 videos on the timeline, one is 11:10:00 and the other is 02:03:00. they are .movs from a Canon DSLR. so i think thats H.264 in a .mov container
also there is 1 .png file at the start of the video
The videos are cut down and the whole timeline is 12:49:00
The compissition is 12:49:00
but the output file is 11:13:00
Here you can see the export settings
The composition settings inside of AE
and the section of the timeline where the movie ends (11:13:00)
you can see there is nothing making it stop at this point. The end and start of the 2 videos don't meet at this time
what could be making it stop short?
I have gone in and checked the export settings before rendering the video to make sure the time goes to 12:49:00
the output is a 720p video at 29.97fps
EDIT: i opend AE and the file i was working on while media encoder was still working on exporting the video and now its stuck, it just says Reading XMP... and the loading bar is doing the stripy moving thing.
guess i shouldn't open AE while its working :S
    Jun 10, 2012 2:47 PM   in reply to russian_box
    Nothing stands out as an obvious cause for the error.
    Jun 11, 2012 6:46 AM   in reply to russian_box
    If this is a final export, maybe try Linking through Premiere Pro before going into AME.
    If it's to be used for further editing, definitely choose a lossless intermediate, like Uncompressed or by installing the free and lossless UT codec on your system.
    Jul 16, 2012 11:12 AM   in reply to russian_box
    We had this problem too. If we set Source Range to Entire Composition, the output is the wrong length. However, if we set the Source Range to Working Area, the output is the correct length.
    I'm curious to know if this works for you as well.
Bookmarked By (1)
