Forms Javascripts
Jul 10, 2012 2:50 PM
Hi, I'm not sure if I should ask this question in this forum or use the Adobe Javascript forum.  I have a form that needs to have a javascript in it.  I have Adobe Acrobat X.  What I need it to do is this:
If a user entered a Posted Speed in the Text Field, the Check box for Prima Fascia cannot be selected.  The same goes the other way, if someone checks the Prima Fascia check box, then nothing can be entered into the Posted Speed Text Field.
Is there a javascript that can be used for this?  Thanks for your assistance.
Connie Bretes
  • George Johnson
    Aug 11, 2002
    Jul 10, 2012 3:13 PM   in reply to csb102155
    It would be easiest to set it up so that when the check box is selected, the text field is cleared and becomes readonly, and when it is not selected, it becomes fillable. Would that be OK?
    Jul 16, 2012 8:53 AM   in reply to csb102155
    When a field is read only it can not interact directly by user input. So, you can only have the check box action change the read only property of the text field.
    Jul 16, 2012 11:22 AM   in reply to csb102155
    I would use the "Mouse Up" action for the check box and set the readonly property of the text field based on the value of the check box.
    Assuming you are using a single check box field named "ChecBox 1" and text field named "Text1" your mouse up action could be:
    if(this.getField(event.target.name).value != "Off") {
    // check box has been selected
    this.getField("Text1").readonly = false;
    } else {
    // check box not selected
    this.getField("Text1").readonly = true;
    // option to clear the field if check box not selected
    this.getField("Text1").value = "";
    or
    if(this.getField(event.target.name).isBoxChecked(0)) {
    // make RW
    } else {
    this.resetForm(["Text1"]);
    // make read only
