Hello
I would like to know how to copy/paste a "grade/color correction" from one video shot to another video shot.
(A grade/color correction can be made of several adjustment layers like curves/gradiants/color lookups/levels/saturartions with several blend modes and opacities ect...)
http://www.youtube.com/watch?v=Vk59s3BQ9MY&feature=youtu.be
As you can see clipping mask need to be re-created.
Noel
Can I copy / paste a grading without having to do all this thing....
Shift click>Cmd-J/duplicate layers>Drag/drop layer> re-create clipping mask ?
You're kind of asking the wrong person; I only vaguely understand what a grading is.
What you're showing in the screen grab above are adjustment layers in Photoshop, clipped to a film clip layer. What I'm saying is that if you select all those layers (highlight them in the Layers Panel) you can chose Layer - Duplicate Layers and duplicate them all together, just as they are in this document, in another document.
Beyond that - how this applies to video - you'll have to talk to someone more expert and experienced in doing those operations.
-Noel
OK, I think I see from your video, which I had missed the link for before, what you want to do.
You want to apply the SAME set of clipped adjustment layers to several different videos.
I would suggest creating a group containing all the clips you want graded the same, then applying the "grading" adjustment layers clipped to the group.
-Noel
Glad that you mentioned the Layer Group, as that would have been my thought too. Then, just Duplicate that Layer Set, and add to each Frame.
Unfortunately, I use Adobe Premiere Pro, or After Effects for most of that sort of operation, and each offers a couple of ways to reuse the "adjustments," which are done mostly with various Effects, and are also applied to whole Clips, and not to a single Frame. In those programs, one can Save a Preset for some, and can always Rt-click on one Clip, after the Effects are added and adjusted, then Select other Clips, and Rt-click, choosing Paste Attributes.
PS - Extended MUST have similar, but I am just not familiar with exactly how things work in it.
Good luck to the OP,
Hunt
Noel,
I think that you are correct on that. Not sure that each has ALL the features?
I really need to turn my back on PrPro and AE for a few weeks, and explore PS - Extended a bunch. Lot of PS Video questions popping up, but when they get beyond general CODEC questions, etc., I can't really help that much. Yeah, a few weeks ought to teach me some useful things.
Hunt
That's tough for me to say, because this time around I upgraded to Extended, so I don't really know exactly what Standard looks like.
I've always wondered why Adobe, at least during the trial period, didn't program a setting that would allow the user to limit the application to Standard edition features only. Then it would be easy to evaluate. But of course they don't want it to be easy for anyone to know they don't need to spend the bigger bucks for Extended... ![]()
-Noel
For me, it has just been the Production Studio, that had Extended, so that is what I got.
Going back, I tried to just upgrade CS 3 to Extended, but found that I could not. Though I had three separate licenses for PS, and only one was ever used in an upgrade path, once I did that, the other two would ONLY work to upgrade the entire suite, and I could not upgrade just one program - PS. I declined, and did not even bother with CS 4, as PrPro had some major issues.
By the time that I finally got PS - Extended, with CS 5, I had retired, so was no longer using PS (or PrPro), like I was earlier. OTOH, I do now have more time, and need to experiment more.
In the case of my upgrade path, there is not a price difference, as with my suite, there is no PS (non-Extended).
Hunt
So you want me to re-edit the shots out of order and then re-edit them in the order of the cut. That is too much work with 500 to thousands shots per jobs. I too use AE, Smoke, Lustre, Resolve, Speedgrade ....etc. But I fine that PS-CS6 has to most comprehensive tools for what I need too do.
Again, I have no insight into the specifics of what you're doing (as I use Photoshop for still image work), but if you need the same adjustments done to a whole group of things, it seems to make sense to group them, no?
It seems you're trying to use Photoshop for something it was not designed to be best-in-show at. I take it that it has features other than layer manipulation that make it attractive for use for this purpose.
-Noel
Like Bill said you can duplicate the LayerSet; to base the Clipping Mask on a new video layer move that one below the Clipping Mask Group, select its base layer, Clipping Mask that to the layer below and remove it.
And if you use one Group set to Blend Mode Normal per video layer the Clipping Mask should be unnecessary.
C.pfaffenbichler
I know how to re-create a clipping mask and all. But is there an easy way like in AE,
> select the layers > copy > select the new layer > paste and keep pasting all the similar shots.
or >create an animation preset > click and keep clicking ?
I have 4minutes 34seconds 18frames made of 467 shots. There is about 31 scenes wich are cut through out the 4 and half minutes of footage in rendom order.
The decription you're giving is a good idea but doesn't work for me. If I move the top video layer under the new cmd-J adjustment clipping masks it become a clipping mask itself, then the preview shots disappear in the time line, then I need to release the clipping mask of the moved video layer.
Could you write down a step by step or make a youtube video of an easier way? Or is there a sript somewhere?
Forget Clipping Masks if you don’t get or like them and put each video Layer in a Group of its own and set that to Blend Mode Normal (alt-shift-N with the Move Tool selected for example or the dropdown-list at the upper end of the ayers Panel), then Adjustment Layers in that Group will only affect Layers in that Group.
That way you can select a bunch of Adjustment Layers, duplicate them and move them into another Group and their effect will be limited to the Layer(s) in that Group.
How many different combinations of Adjustment Layers are you likely to apply?
Maybe one could automate parts of the task.
But is there an easy way like in AE, > select the layers > copy > select the new layer > paste
No, Layers in Photoshop cannot be copied; pixel content, texts and paths can be copied.
I don’t quite follow.
http://www.youtube.com/watch?v=ksX2CruyRLU&feature=youtu.be
This video is to explain comments about moving the video layer under the adjustment layers.
http://www.youtube.com/watch?v=6HzWTMb5Rxk&feature=youtu.be
Now I am now trying the layer gouping and it doesn't work because it is affecting the previews shot as well.
disclaimer: This footage was found on the internet and is not mine.
Please keep in mind that I have 500 shots already edited ( meaning cuts, dissolves, fades etc ..) and my client and I would like to keep it that way (other wise it would be an incredible amount of work). All I need to do, is gradings, filters and textes for the final cut.
Thanks for helping anyway:)
You have to do something to 500 different clips, and you'd like it to be as simple as possible. We get that.
Unfortunately, you're not just going to be able to copy the set of adjustment layers and have them be automatically clipped to the layer they're pasted in front of. You proved that.
So you have to copy the set of layers, paste them in front of a video layer, then clip them. Seems like only a tiny bit of additional work to me. Did I miss something? You are aware you can set all of the layers highlighted to clip to the layer below them at once with Alt - Control - G, right?
-Noel
