I'm on a Mac, 10.6.8 and PS CS5 12.0.4 with a Wacom Intuos3.
I select a hard round brush and turn off the Transfer > Opacity Jitter > 'pen pressure' option. However as soon as I thouch the tip of my pen down pen pressure turns back on. This is annoying when trying to do a detailed cutout in a layer mask as it leaves behind opaque areas that aren't always visible right away.
Even if I create a new preset with pen pressure off, it comes back on once saved. So how do I get around this? There must be a way to turn off pen pressure while using the Wacom tablet. Am I missing something?
Yes there is a Wacom control panel on the Mac. There are options to change the tip feel from softer to harder, but nothing to disable it completely. Good idea though, I hadn't thought to check there.
I read somewhere else to uninstall the Wacom drivers, but doing that makes the tablet pretty much usless. i.e. the pen moves slooooooow, and on a 24" monitor it's practically unusable.
I'm in the middle of a work day, so I can't trash my preferences at the moment. But I did try resetting the tools preferences and that seems to have worked. (Hold cmd + option + shift on startup; alt + ctrl + shift on PC) I guess something I did with my brushes settings at some point made things funky. Now I can uncheck all the Brush Tip Shape options and use the tablet no problem.
Thank you all for the help and sugestions. I appreciate it.
Two things that I can think of:
1) If you are using a custom brush, then you should be aware that any changes you do to the brush (such as turning off pen pressure or adding radial scattering) won't be saved unless you define your settings as a new brush preset.
Tiny triangle icon at the brush panel (right click on canvas when brush tool is selected) > Define new brush preset
2) This is just a guess, but it is possible that some pen tablets come with drivers (or software) that overrides other software. This is common practice with graphics cards but I've seen this trend on other types of hardware as well (such as keyboards). Is it possible that your pen tablet software/drivers are overriding whatever settings Photoshop tries to change? You can try this out by uninstalling your tablet drivers and let windows pick some default drivers for it - then try out Photoshop and see if the problem is still there.
OK i have windows but i hope this will work for you too (and others that might read this
!Before turning on the computer, don't have the tablet connected.
1. turn on computer
2. open photoshop
3. plug in your tablet
4. draw ![]()
For some reason (at least for me), if the tablet is connected after you open Photoshop, the program doesn't recognize pen pressure anymore.
Hope it helps, let me know ^_^
